Old 12-05-2020, 05:42 AM
Florida Boy Florida Boy is offline
Default Outboard leading edge skins
In preparing the skins for my outboard leading edges I'm surprised not to find a step in the plans calling for slighthly breaking the very aft edges of the skins in order to form a tight lap seam against the main spar flange when riveted.
That technique has been specified and has served very well in several previous applications, most recently the top skins.
Is there any reason that the plans are not calling for this technique on the outboard L/E skins at the spar seam?
Thanks for any suggestions.
Randy Carmichael
Rookie Builder
Melbourne, FL (KMLB)
Old 12-05-2020, 06:17 AM
1001001's Avatar
1001001 1001001 is offline
I can't speak for the RV-14, but I did not break those edges on my RV-10 leading edges or fuel tanks, and the alignment with the main skins is perfect.
The shape of the leading edge ribs seems to pull the skins so they are tight around the spar. Try fitting your leading edges to the aft wing section when they are just clecoed together and I expect you will see the same thing.
Old 12-06-2020, 05:36 AM
RV6-KPTW RV6-KPTW is offline
Hey Randy,
I don’t recollect breaking those specific edges. I do remember following directions more or less, and that trial fits dictated whether I adjusted. If the trial fit did not look good, I did break edges.
Dennis Callaghan (X26)
- RV14 sn:140193 - first flight 12/19/2019
- 2000+ hours on my RV6! Sold (so sad...)
- donation 12/18/2020 * 2
