Old 08-10-2015, 05:22 AM
david.perl's Avatar
david.perl david.perl is offline
Default Tyre pressure
Am confused as to what to use for the stock tyres on a 7A
would be interested to hear what others are running at
thxs
David
SB RV 7A IO360 lycoming and Hartzell CS prop
First flight October 2015
Old 08-10-2015, 06:56 AM
Walt's Avatar
Walt Walt is offline
thxs
David
I use 45 PSI all around.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Lemmingman's Avatar
Lemmingman Lemmingman is offline
Hi David,
There are many threads on VAF dealing with tire pressure. I linked this one about tires.
http://www.vansairforce.com/communit...ad.php?t=99093
Gil Brice
McKinney, TX EAA-1246
RV7 - Working on fuse, fuel, brakes etc...
Old 08-10-2015, 07:15 AM
DanH's Avatar
DanH DanH is online now
I looked in all my literature, and I can't find anything about "tyres"
Dan Horton
RV-8 SS
Barrett IO-390
Old 08-11-2015, 06:31 AM
David Z David Z is offline
They don't have "tires" where he's from, just "tyres". Thankfully, they're both round and typically made from rubber.
RV-8
Empennage Passed Pre-close Inspection
Wings mostly done
Fuselage started
83126
Dash 8 day job is financing the RV-8
Donation till September 2021
Old 08-11-2015, 06:52 AM
AndyRV7's Avatar
AndyRV7 AndyRV7 is offline
thxs
David
You are probably confused for good reason. There doesn't seem to be a consensus on the topic. I run mine at 35 psi because that is the pressure my builder suggested. But they don't hold pressure very well until the get to be some place around 30 psi. Some days when I add air I go to 40 psi just because I know they will settle a few pounds lighter.
When I was trying to get some insight into the topic, I read a lot of threads in here and it seemed like everyone used a different pressure. Maybe anywhere from 25 psi to 50 psi???
Good luck! Andy
Old 08-11-2015, 07:15 AM
BillFear BillFear is offline
Default after some experimentation
We like 45 in ours. use michelin leak-stop tubes and you will rarely have to service them.
Bill Fearheiley
Lake Norman, NC (14A)
RV7a N705RP (no longer own)
Contribution in for 2017, money well spent
Old 08-11-2015, 07:22 AM
swordtail swordtail is offline
I use 50 all around on my 6A.
Old 08-11-2015, 07:56 AM
BABALU BABALU is offline
Lightbulb
I'm pretty sure that was the PROPER English spelling before we on this side of the pond decide to create our own version. Why don't you check with Webster.
A C Tyler
RV 9A
Old 08-11-2015, 08:37 AM
Infidel's Avatar
Infidel Infidel is offline
I'd say your tire/tyre pressure is going to be dependent on what type of field surface you operate on. As mentioned earlier, 35#'s is a good comfortable pressure and you can adjust it from there to your liking.
