Old 09-26-2021, 11:50 AM
wirejock's Avatar
wirejock wirejock is offline
Default Vinyl panel skin
Does anyone know how to convert a DXF Cad file to a Vector file to print on vinyl?
I have this beautiful CAD drawing with labels on a separate layer so the vinyl skin can be printed and apllied. The vinyl places want a fortune to convert it like it's some sort of government secret from Area 51.
This is the beauty of experimental. We do stuff on our own. I get really irritated when someone won't share techniques. If I figure it out, as with all my tips, it will be shared so others can do it.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Empennage, wings, fuse, finishing kit, now FWF
Disclaimer
Old 09-26-2021, 11:59 AM
flysrv10 flysrv10 is online now
I may be able to help. Not promising since I have not done this before but internet sez I can.
Send you DXF file to flysr10 at gmail and I see what I can do.
Old 09-26-2021, 02:49 PM
wirejock's Avatar
Default File conversion
Awesome. Thanks
I am making final tiny corrections. When it's done, I'll reach out.
Larry Larson
Estes Park, CO
Disclaimer
Old 09-27-2021, 08:04 AM
Snowflake's Avatar
Probably because people who do this for a living want to be paid for their work?
Rob Prior
Old 09-27-2021, 08:20 AM
wirejock's Avatar
Default Job
I'm sure that's the reason.
Larry Larson
Estes Park, CO
Disclaimer
Old 09-27-2021, 09:04 AM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Try this https://cloudconvert.com/dxf-to-svg
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 09-27-2021, 09:21 AM
wirejock's Avatar
Default Convert
Originally Posted by pazmanyflyer View Post
I think we have a solution. AutoCAD will save in other formats. We are going to try saving as an .EPS file. I will also see if it can save as .SVG. Then I need to find another vinyl printer.
Larry Larson
Estes Park, CO
Disclaimer
Old 09-27-2021, 02:35 PM
krw5927 krw5927 is offline
I used Corel Draw to import a CAD file of my panel (pretty sure it was DXF), create graphics and words on a colored background, and sent it to the local sign shop to print a big vinyl sticker. No painting, no individual labels to misalign...
Kurt W.
RV9A
FLYING!!!
Old 09-27-2021, 03:18 PM
wirejock's Avatar
Default Big label
That's exactly what I'm trying to do! I have a DXF with multiple layers. We are working out the final details. One layer is all the holes and cut lines. Another layer is all the labels. The idea is to print the cut lines on sacrificial vinyl. Cut ir drill all the holes. Remove the cut vinyl. Clean up the panel. Print the final on some nice carbon fiber. Install goodies. Future adjustments using the original drawing should be easy to reprint. Easy peasy right? Famous last words. I will detail the process if it ever gets done!
Larry Larson
Estes Park, CO
Disclaimer
