Keep VAF
Going
01-22-2017, 01:08 PM
Moderator, Asst. Line Boy
RPM-MAP limitations
I have a relatively new 230 tach-hour Lycoming IO-360-M1B with a newly installed Hartzell C2YK-1BF constant speed prop. Searching the documentation that came with both the engine and prop, I don't see any limitations on prop RPM/engine manifold pressure (other than a 2700 max prop RPM). Specifically, I see no ranges or combinations to avoid.
I want to be sure I don't omit appropriate ops restrictions from my POH, but am not interested in incorporating WOM (word-of-mouth) practices not backed up by factory documents.
Does the VAF brain know of RPM/MAP combination restrictions for my engine/prop combo?
Scroll
Exemption waived.
Proud and grateful 2022 -=VAF=- Contributor
PS: I am not an influencer. I have no influence. Just ask my kids.
01-22-2017, 01:37 PM
Popping the popcorn now!  Who will be first to say "oversquare" ?
Pete Hunt, [San Diego] VAF #1069
RV-6, T-6G
ATP, CFII, A&P
2022 Donation+, Gladly Sent
01-22-2017, 02:56 PM
The posts noted below from Les Doud may be of assistance.
The -M1B has no RPM/MAP limits by itself from Lycoming, unlike some of the angle valve motors that have been shown to have a lower detonation margin.
I can only speak to one -M1B and prop combo which is the 7497 BA bladed compact hub prop sold through vans.
Per one of the links below, that one has no operational limitations.
Prop limits 1
Prop limits 2
Bill Pendergrass
ME/AE '82
01-22-2017, 03:45 PM
Originally Posted by RV8JD
The Hartzell website points to Note 9 in the Type Certificate Data Sheet (TCDS) for limitations for homebuilt aircraft. I would contact Hartzell directly since the propeller TCDS does not appear to list your combination directly (see link below). But the first line on page 9 lists your prop with various parallel valve O-360s. I don't recall if the -M1B is just a parallel valve -A1A (or -B1B) with FI. That shows a limitation of "Avoid continuous operation between 2000 and 2250 RPM", but it depends also on the blade type installed on the C2YK hub.
http://rgl.faa.gov/Regulatory_and_Gu...-920_Rev37.pdf
It does show the IO-360-M1B with the C2Y R prop hub with F7666A blades on page 10. That shows a limitation of "Avoid continuous operation between 2000 and 2350 RPM"
Also, whether you have Mags or EI will make a difference, and EI is not covered in the TCDS.
The link above points you to the Type Certificate Data Sheet. You need to know what BLADE is used with the Hartzell hub listed. I am aware of 3 different blades that have been used with the parallel valve 360 in Hartzel hubs.
The Mother Ship has links to two documents for Hartzell Prop limitations.
F7666A blade
F7496 blade
Going from memory, the F7497 blade is the one that I would desire on a NEW RV.
Gary A. Sobek
NC25 RV-6 Flying
3,500+ hours
Where is N157GS
Building RV-8 S/N: 80012
01-22-2017, 08:40 PM
Thanks, all, I learn more and more every day (thanks to VAF). Looks like I need to know not only the prop model number, but the blades' and hub's model numbers and serial numbers. Then contact Hartzell for the bottom line. I'm on it.
Bill Lane,
I got your email and will give Les Doud a call tomorrow.
Scroll
Exemption waived.
01-23-2017, 09:05 PM
This is why VAF is worth the annual donation...and much more
Many thanks to Bill Lane, who got me in touch with Les Doud at Hartzell props. Les was able to look up my prop through its serial number, thus ID'ing my exact blades and hub. That, compared to my engine, helped him determine the precise engine/prop ops limitations for my particular aircraft. According to Les:
""This propeller model at 72? on the IO-360-M1B has the following operating limitation: ?Avoid continuous operation between 2000 and 2350 RPM.? This operating limitation is referenced in TCDS P-920, Note 9 (available on the FAA website) for propellers down to 74?. I consulted with our Test Engineer and he confirmed this would also apply to 72? diameter.""
In addition, he let me know that this prop/engine combo can sustain up to a 10% rpm overshoot above the 2700 rpm redline for up to 20 seconds without need to remove and inspect.
I'm rolling these into KELLI GIRL's POH. Thanks, everyone. VAF rocks!
We're mission complete.
Scroll
Exemption waived.
01-24-2017, 11:53 AM
I have an IO-375-M1S (Aero Sport Power), 8.5:1, 195 hp, dual P-Mags with a Hartzell HC-C2YR-1BFP/F7497-2 prop. Since Hartzell haven't tested this combination they recommended I go with the most restrictive placard i.e..Continuous operation is prohibited above 24 inches of manifold pressure between 2350 and 2550 RPM.
Dennis Enns
Bellanca Champ 7ACA since 1986, restored 1990.
RV-8 IO375, MTV-9-B/183-50a, PMags, OW Award Oshkosh 2017
2022 Donation In
01-24-2017, 12:37 PM
Scroll; if you don't mind my asking, how much did the prop change move your c of g?
Gerry Julian
Moose Jaw Saskatchewan
RV6A "Second Wind" C-GERZ (born N242UL)
O-360 A1A, Sensenich FP prop
Those who think any system is foolproof greatly underestimate the ingenuity of fools
01-24-2017, 10:14 PM
Gerry,
Not that much. Before it was 80.75", now it's 80.61". Weight did increase, though. It went from 1161 lbs to 1185 lbs.
Let me add, though, that this as a COMPLETELY DIFFERENT airplane. Huge performance boosts in takeoff and climb, plus drastic differences in managing acceleration, closure, and especially deceleration in formation flight and formation rejoins. Cruise speeds did not change, but fuel efficiency improved by 1 to 1.5 gph depending on altitude and power levels. Ant talk about a smoother engine/prop noise level...sweet!
Totally worth the money...but did I mention that my old FP prop is for sale?
http://www.vansairforce.com/communit...d.php?t=145975
Scroll
Exemption waived.
01-25-2017, 08:51 PM
Originally Posted by scrollF4
Gerry,
Wow...I thought the cg would move more than that. Good to know! I have the same Sensi prop on my plane that you had (so, no, I wouldn't be looking to buy your old one lol) and concern over messing with what is right now a really good cg location on my plane is one of the things (well, that and the $10g's it would take) that has stopped me so far from converting to constant speed. Your results are encouraging. BTW, you were camped one row over from me in HBC this year; I checked your plane out but never had a chance to talk to you. Missed opportunity!
Gerry Julian
Thread Tools |
Display Modes |
