Old 10-05-2021, 08:46 PM
rvator4twa rvator4twa is offline
Default Rudder trim
Has anyone installed the Aerosport products rudder trim system in your RV-6(A)?
I have purchased it, not yet installed. I am hoping by trimming the rudder for cruise that the autopilot will fly wings level. Did you have any issues on installation or after?
Ron Burnett N524RB
RV-6A Lycoming O360 dual EFII system 32
Vinyl wrap-tired of polishing
M71-Greensfield, MO near St. Louis
USMC combat exempt but dues gladly paid April 2021
Old 10-05-2021, 09:42 PM
N626JT N626JT is offline
I installed the Aerosport rudder trim system in my RV-6A. It wasn't easy working under the panel but only took a couple hours to install. It works great and it flies wings level with the autopilot engaged.
Old 10-06-2021, 08:35 AM
Default Rudder trim
N626JT,
One of my questions at least in thought is, if I have the mounting holes on top which seems logical, turning the knob to the right causes the left side to pull. Is that correct? I plan to mount it about center bottom panel, underside with the arms pointed downward. Is that what you did? Do you have a photo?
Ron Burnett N524RB
Old 10-06-2021, 07:28 PM
Ron,
I will look at my installation tomorrow and try to get some photos for you.
John
Old 10-07-2021, 05:36 PM
I installed my trim control knob under the panel with the mounting holes up. the arms need to be installed pointing up, if they point down you would be pulling slack in the rudder cables. The right side arm attaches to the left rudder pedal shaft and the left side arm attaches to the right rudder pedal shaft. Hope that makes sense.
Old 10-12-2021, 09:22 PM
Default Rudder trim
Sent a private message before I read this. Would still appreciate a photo or two if possible. Will look again tomorrow
Ron Burn
Ron Burnett N524RB
