Go Back   VAF Forums > Regional Forums > International
Old 02-11-2019, 10:00 AM
JoopSJ's Avatar
JoopSJ JoopSJ is offline
Default Builder info from France, Germany, Austria and Sweden requested
Hi all,
As a board member of the Dutch Amateur Builders Club, I need some information on the EAB regulations in several countries in Europe.
I would appreciate if someone could provide next information.
I have made one thread for each country I need information on.
[duplicate threads deleted and title edited to combine all deleted threads into this one; S. Buchanan, moderator]
Building:
- Inspection during build:
- If yes inspecting authority:
- final check for airworthiness by whom:
Flying:
- Basic instruction allowed on EAB? Restrictions?
- VFR by night allowed?
- if yes, requirements?
- IFR allowed,
- If yes, requirements?
- Does the regulation state you have to avoid polulated/ build-up areas?
Maintaining:
- Can the builder perform maintenance?
- Can non-builder perform maintenance?
- Can builder sign-off inspections or annuals?
- Can non-builder sign-off annuals?
Import
- can you import half finished kits from the US or other EU states?
- can you import finished aircrafts from the US or other EU states?
I would be very thankfull if I could receive any relevant documents:
joop
sintjago.nl
Thank you very much.
Empennage, Wings, Fuse .. Done
Working on Finishing and FWF
Donation 2017. . . 2020
Chairman NVAV (EAA chapter 664 - Dutch experimental aircrafts builders)
Member EAA
Member AOPA
Old 02-13-2019, 07:23 AM
JoopSJ's Avatar
Default Thank you
Very useful and exactly what I am looking for.
I will contact you via PM.
Best regards,
Joop
Member EAA
Member AOPA
Old 03-09-2019, 01:28 AM
High_Flyer's Avatar
High_Flyer High_Flyer is offline
Default In France
Hello,
I Have built and now fly a RV-7 in France.
Here is what I can tell you:
Building:
- Inspection during build: Yes, one before closing the wings, one before 1st flight
- If yes inspecting authority: OSAC https://www.osac.aero/index.php
- final check for airworthiness by whom:same as above
You must first open a file with OSAC (delegated by the French DGAC for homebuilts amongst other things) and to obtain a file number and if you whish to reserve your registration marks.
Flying:
- Basic instruction allowed on EAB? Yes Restrictions? I don't know...
- VFR by night allowed?Normally no
- if yes, requirements? Very complicated to obtain, must demonstrate to the authority that the equipment and systems are compliant
- IFR allowed Normally no, same as above
- If yes, requirements? Same as above
- Does the regulation state you have to avoid polulated/ build-up areas? No
Maintaining:
- Can the builder perform maintenance? Yes
- Can non-builder perform maintenance? Initially no, yes after meeting certain requirements
- Can builder sign-off inspections or annuals? Yes
- Can non-builder sign-off annuals? Initially no, yes after meeting certain requirements
Import
- can you import half finished kits from the US or other EU states? NO
- can you import finished aircrafts from the US or other EU states? NO
Contact the Vans Club de France for further info http://vansclubdefrance.fr/index.html
We have our annual fly-in on 14-15-16 June, in Pont sur Yonne near Paris. I suggest you come and talk to us it's a great week end:http://vansclubdefrance.fr/fly-in-pont-sur-yonne.html
Pre-registration is recommended if you whish to come.
regards
RV7 (F-PRVZ), Tip Up, Aerosport IO-375, Dynon Skyview, VP-X, Day VFR.
Flying since June 2017.
Old 03-11-2019, 01:11 AM
JoopSJ's Avatar
High Flyer, thank you very much for the info. Very use full.
The fly-in weekend is noted in my agenda.
I will let you know if I am able to attend.
Best regards
Member EAA
Member AOPA
