Keep VAF
Going
12-17-2019, 05:40 PM
That looks really good.
I can see you took into consideration minimizing the connector as the original is just as deep as the GMU itself.
12-17-2019, 05:45 PM
unfluencer
I'm hoping to get Stein to help me work out any connector kinks (pun). Hopefully he can make me a dongle.
Really like how Tony blew this out of the water. Amazing work!!!!
Doug Reeves (your host) - Full time: VansAirForce.net since '07 (started it in '96).
- Typed in the EMB-505 (Phenom 300). Available for contract work. (resume).
- Part time: Supporting Crew Member CAE EMB-505 Level D Sim @ KDFW.
12-18-2019, 06:51 AM
Awesome! Will the GMC307 fit into this?
Is GMC307 the same size as the GMC507.
If not, any chance there will be a version for the 307?
Empennage, Wings, Fuse .. Done
Working on Finishing and FWF
Donation 2017. . . 2020
Chairman NVAV (EAA chapter 664 - Dutch experimental aircrafts builders)
Member EAA
Member AOPA
12-18-2019, 07:39 AM
Same size
GMC307 and GMC507 are the same size, share the same connector, tray, rack, etc.
Only difference is the addition of the TRK key ('507) and the interface moves from RS-232C('307) to CANbus ('507), and a TO/GA input('507) , so the connector pinout is slightly different.
Brian Decker
Retired Firmware Guy and Airplane Builder
2020 RV-14 QB -- Under construction - Tailcone & Empennage Complete.
2018 RV-7 QB -- Built, Flying
2007 RV-7 QB -- Built, Drowned, Resurrected and flying
1998 RV-8 QB -- Started, Sold
1986 Mooney 205SE
1980 Mooney 231
Aided and abetted building a number of other RV's.
Reason: audio vs TO/GA
12-18-2019, 07:53 AM
looks good
I am excited for you guys on this. Another printed application! Can't wait to see it installed.
Steve Melton
Cincinnati, OH
I was born an airplane nut. I have no explanation for it.
www.rvplasticparts.com
01-14-2020, 02:31 PM
This is looking great, I just saw the pictures on your panellove smugmug. Any idea when it will be available?
I reached out to ClassicAero to see if they would make a glareshield trim piece to match  Here is their current product, which I have and really like:
http://www.classicaerodesigns.com/we...oductID=59&a=2
[ed. Short answer, I think 'soon'. When Tony is happy with the 3D printing, he'll send me the SW file and I'll host it for free download. v/r,dr]
RV-9A - started 01/2015, completed 07/19/2018, 500hrs 03/14/2020
RV-10 - started 04/2020
01-14-2020, 04:19 PM
The 307 is about an eighth of an inch deeper than the 507. If this housing is designed with the 307 in mind it will fit the 507 but not vise versa.
Darin
Snoqualmie WA
RV-9A Sold
RV-10 Building - Working on the last 90%
www.DarinAnderson.com
2021 donation sent!
01-14-2020, 04:28 PM
Originally Posted by gfb
Just heard back from ClassicAero and they would be happy to make a fitting glareshield trim. Once I print one of these up they will ship me the base material for me to cut to fit and ship back to them for them to finish.
01-17-2020, 04:44 PM
Hey DR, just a heads up that the GMC requires an electrical ground on both clamps. If you put this in a plastic housing you wont have that ground. An alternative that I ran past G3Xpert already would be to run a ground from the backshell of the connector to your forest of tabs. This is assuming you have electrical continuity from the clamps to the backshell. I tested my GMC507 and had good conductivity. In the drawing above you don't have a back shell but you should be able to ground similarly using the standoffs that the backshell would normally connect to.
Darin
Snoqualmie WA
RV-9A Sold
2021 donation sent!
04-22-2020, 12:40 PM
Hey Doug
Any progress made on the design of this rig? I would really like to make one for my 307.
Cheers
Mark
RV-8 C-GURV (Flying since Nov 2004) - Sold
Scratch building 4pl Bearhawk
Flying a '79 Maule M5-235C
President EAA 245 Ottawa, ON
Thread Tools |
Display Modes |
