alpinelakespilot2000
RV-9 stall speed - Vso (solo)? + do mine look about right?
Does anyone know what Van's no flaps solo weight stall speed is? On their website, they provide the numbers solo and gross for what I assume are flaps down speeds (Vso), but can't find equivalent numbers for flaps up stall speed (Vs) at solo weight.
Went out and did a full stall series and am interested by the IAS's I was seeing compared to the book IAS speeds Van's provides. I'm curious whether my lower indicated stall speed for Vso is what other RV-9/9A's see and whether that's just indicative IAS inaccuracies at such low speeds, whether it's a function of my relatively low empty weight (1039# me, 1057# Vans), whether I likely have a significant pitot and/or static error, and/or whether I have to be more careful at what altitude I do them. (I did mine at about 5000-5500 ft density altitude. Anyone know at what altitude Van's does theirs?)
If you fly a 9 or 9A do my indicated speeds seem in the ballpark compared to yours when you're at 5000 ft density?:
Vso: Vans = 44mph/38kts (solo weight); My plane = 40mph/35kts (solo weight = 180# + full fuel)
Vs: Vans = (can't find Van's Vs numbers for solo weight); My plane = 50 mph/43kts (solo weight = 180# + full fuel)
FWIW, though my GPS speeds seem to match up pretty well with my indicated and true airspeeds when the wind is factored in during cruise, I haven't had a chance yet to really check my IAS in general using the 3-way or 4-way tests and their associated formulas.
Thanks.
Thanks.
