Leland
I thought the following data might be of interest to RV9A pilots.
This data was taken on my recent trip to Vetterman?s Black Hills Flyin. (This was by far the best flyin that I?ve been to.)
The fuel-burn rate for the 2.9 hour flight from Livermore, California to Wells, Nevada averaged 6.2 gallons/hour (GPH), including the full-throttle climb to 13,500?, cruise and decent. The burn rate at 13,500?, with the mixture leaned to the edge of roughness, was 6.0 GPH while cruising at 146 knots TAS. (The density altitude was 14,900?.) The cruise burn-rate was measured over a 20 minute period since the instantaneous EIS reading fluctuates. The full-rich, full-throttle TAS at this altitude was 150 knots (2460 RPM and 18.4" M.P.).
The second leg of the flight from Wells to Kemmerer Wyoming at 11,400? showed a TAS of 156 knots at 2540 RPM and 20.1" M.P, for full-throttle and full-rich conditions (burn rate was estimated at 6.9 GPH).
The maximum TAS of this plane near sea level is 162 knots. Its airspeed indicator is accurate to 1-2 knots.
Leland
Faired and painted RV9A
550 hours since new on a carbureted O320D1A
One P-Mag and one conventional magneto
Catto fixed pitch 3-blade propeller
Leland
