Old 06-01-2021, 08:23 PM
VA Maule VA Maule is offline
Monkey butt anti chaffing powder is mostly talc.
Maule MXT-7(daily flyer)
Lancer 235(partner)
Raidial RV-8R Ephanage Done, Wings Done, Fuselage on it's tall Grove gear & engine hung
Old 06-01-2021, 08:40 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Originally Posted by AlexPeterson View Post
I've been using baby powder for 20 years.
Iíve been doing the same thing - never a problem!
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 06-02-2021, 07:35 AM
Jvon811's Avatar
Jvon811 Jvon811 is offline
My baby powder is Lavender scented... It does make the process slightly more calming and enjoyable for me. The tubes must stay calm in the tire too because I haven't had a problem in years.
-Justin
RV-4 N249P
O-320, Dual P-Mags, Warnke Prop, Short legs, Manual Flaps, GRT Sport EX
Old 06-02-2021, 08:02 AM
jliltd jliltd is offline
Make sure your baby powder is actually talc. Much of it is now corn starch based, which seems to work fine for changing diapers. That might come in handy in a few years, speaking personally. However, DO NOT use non-talc powder on your tires and tubes. The corn-based stuff absorbs moisture and gets clumpy over time. So you can end up with small hard nodules of corn starch that can grind away at or even puncture your inner tubes months or years down the road. And make sure you use lots of extra real talc if you use Aero Classic (Desser) Leak Guard tubes made from Butyl. The mold lines on those tubes are very susceptible to tear out in the presence of corn starch, especially at low air pressures where there is movement between the tube and tire surface. The Michelin Air Stop Butyl tubes don't seem to have this kind of problem. But talc 'em all.
Old-fashioned talc products = yes
Non-talc baby powder = no
RV-8
(and a few more airplanes)
Old 06-02-2021, 08:11 AM
bkervaski's Avatar
bkervaski bkervaski is offline
I bet your airplanes smell great
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
