Old 06-07-2021, 08:55 AM
Plummit's Avatar
Plummit Plummit is offline
Default Replacing Magnet for door switch
I have started getting false "Door open" indications on my PFD. The problem was traced to the reed switch magnets which are very weak. I had already purchased a new door switch kit from Vans which came with new, much stronger magnets, magnets. Has anyone changed the magnets in the door pins and how did you remove the old magnets?
-Marc
RV-10
N814RV
2021 Donation Made
Old 06-08-2021, 07:52 AM
lr172 lr172 is offline
May be a pain to dig them out of the pins.. maybe consider making a mechanical switch instead. Probably a couple of bucks at digikey. Just need to make an adjustable holder.
Old 06-08-2021, 08:25 AM
Plummit's Avatar
Yes Larry, that (the mechanical switch) is what we plan to do. I was hoping to not have to reinvent the wheel, but those magnets are epoxied in. You can't drill them (at least not easily).
-Marc
RV-10
N814RV
2021 Donation Made
Old 06-08-2021, 08:48 AM
Carl Froehlich's Avatar
Another option is to buy these pins from IFLYRV10:
https://iflyrv10.com/index.html
You thread the door latch rod to receive these pins.
Make sure you order the pins that have the magnets already in them.
Carl
Old 06-08-2021, 09:39 AM
Plummit's Avatar
Thanks Carl, I'll check to see if I already have those installed. The strike plates are there, so maybe the builder installed the kit. Otherwise, I doubt I'll try to install them on my finished door.
-Marc
RV-10
N814RV
2021 Donation Made
Old 06-09-2021, 12:28 AM
rdamazio's Avatar
rdamazio rdamazio is online now
Another option for pins: https://planearound.com/shop/ols/pro...rin-pin-guides (they fit the cylindrical magnet that comes from Vans btw)
Rodrigo Damazio Bovendorp
San Jose, CA
RV-10 builder #41623
Build log at http://www.airplane.build/
VAF dues paid
Old 06-19-2021, 07:37 AM
Plummit's Avatar
We ended up replacing the magnetic switches with mechanical switches and so far they are working great! Bruce Hill found them on Mouser and he used some double-sided mounting tape to install them. I'm pretty sure it's the same stuff as "servo tape" that I used to use on RC aircraft.
Thanks Bruce!
-Marc
RV-10
N814RV
2021 Donation Made
Old 06-19-2021, 05:53 PM
RV10Pilot RV10Pilot is offline
Thanks Bruce!
-Marc
Do you have a specific make and model of the mechanical switch you used?
Old 06-19-2021, 10:22 PM
Plummit's Avatar
Sorry I don't have that on hand but I will get it for you. I'll also take a pic of the front switch. I do know that Bruce bought a "left" and "right" (or fore and aft) switch for the different positions. Stand by.
-Marc
RV-10
N814RV
2021 Donation Made
Old 06-19-2021, 10:37 PM
Plummit's Avatar
https://www.mouser.com/ProductDetail...rrencycode=USD
RV-10
N814RV
2021 Donation Made
