Robin, you are way overstating the differences. Fixed pitch props are not even close to an alternate engine setup, they are as well understood and proven, if not more so, than constant speed. The impact on resale value is relative to the value the individual buyer places on the benefits, or lack thereof, compared to the price, and while it may be a factor in someones purchase or not, I would not expect a "huge" discount just for that fact alone (like an alternate engine setup probably would). And the performance of the airplane with said prop is reflected in the operating manual, so there's no "extra" risk for the owner of a fixed pitch prop instead of constant speed if its been properly documented.
I happen to have an RV-10 with a fixed pitch prop, but am not a good source to answer the original question, as my plane is based in Denver where all my takeoffs and climbing is done at altitude, and frequently hot and high (so I don't have good numbers for sea-level, standard-temperature performance charted out yet); and my prop is an unusual design (Elippse prop).
Dwight
