Brantel
Ok so once this panel upgrade is over, I am thinking about an upgrade to a CS prop later this summer...
My engine has a hollow crank so I am set there.
Just want to understand all I am in for on the swap and to run some assumptions by the group....
I am almost dead set on a Hartzell BA prop since I want the weight up front. I currently have a Metal Sensenich FP. Does anyone know the weight difference between the metal FP setup and the CS using this prop when one considers the total system weight?
Does anyone see any issues running this CS prop on my crank since it has lightening holes in the crank flange?
Here is a list of things that I think I will need in order to make the swap:
- The BA CS prop from Van's
- A prop governor (please make suggestions on what make and model to get, engine has a blank cover over the pad for it)
- Prop control cable (made provisions for it in the new panel....)
- Prop control/governor cable bracket from Van's
- Oil supply line. My engine has provisions but they are plugged. I am thinking braided flex line?
- New CS spinner kit from Van's
- Plug for the rear of the crank (can this be installed without tearing the engine down?)
