Go Back   VAF Forums > Regional Forums > California
Old 12-01-2010, 09:30 PM
bbrvvvvv bbrvvvvv is offline
Talking Any RV-10 builders/flyers in Orange County CA?
Sold my RV-6A and starting an RV-10. I would like to set up a builders breakfast to talk RV?s anyone interested?? I am thinking the Tustin area kind of central to OC. Flyers would be more than welcome too!!
Werner Berry
OC CA
Old 12-02-2010, 09:59 AM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
Default Welcome to VAF!!!!
Werner, welcome aboard VAF
Good to have you here, enjoy the ride.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 12-02-2010, 10:37 AM
Default Werner Berry
That name really sounds familiar. Were you in EAA Chapter 92 before 2004?
Bob Axsom
Old 12-02-2010, 02:31 PM
Default Thanks Guys!!
And a big congratulations to you Mike I hope you have a great first flight!! Thanks for the offer I may just take you up on it someday. Bob I was quite active in the EAA chapter number 92 many years ago. When I sold my RV-6A I bought a large motorhome and have been doing that for the last few years. Thanks for the kind words Mike! I look forward to flying an RV again.....
Old 12-02-2010, 02:45 PM
eison eison is offline
Default I am behind the Orange Curtain
Werner,
I am in Irvine and have some parts that hope to eventually be a -10. I am close to finishing up the wings.
I would love to meet up sometime.
Regards,
Eric Ison
Old 12-02-2010, 08:22 PM
Sounds great Eric! I will put you on the list and send you an email.
Old 12-03-2010, 06:38 AM
Default I though so
I may be wrong but as I recall in 1996 when I started building my RV-6A you were working on your RV-6A. I joined the Chapter and went to a few meetings before dropping out because it just didn't fit into my schedule. The chapter had time in the meeting format devoted to projects currently under construction. If I am correct you are the guy that really impressed me with your extremely well thought out ideas and high quality implementations in your RV-6A. I had worked in aerospace for a very long time even then (42 years) and I knew the difference. I saw the photographs of your fuselage to wing plumbing details using 90 degree bulkhead fittings for the interface of all lines rather than running the tubing through grommets on holes in the fuselage sidewall. That and your routing of the fuel lines, brake lines, tank vent lines and pitot lines inside the fuselage from the MLG structure protected area to their terminations immediately stuck in my head because I knew the original design approach was not acceptable to me and yours was intuitively right. Several years later when I reached that point in my approach was similar to yours. I suspect your meetings will be very beneficial to the builders in the group, quite unlike the largely social EAA Chapter meetings.
Bob Axsom
Old 12-03-2010, 11:30 AM
bruceh's Avatar
bruceh bruceh is offline
If you are looking to connect with other SoCal RVer's, then be sure to join the SoCAL-RVlist@yahoogroups.com email list. Lots of informal get togethers and fly-in's are announced and discussed there.
Bruce Hill
2020 VAF donator
Old 12-03-2010, 12:19 PM
Chino Tom's Avatar
Chino Tom Chino Tom is offline
Werner Berry, the original pied piper. Now we'll all have to build 10's!
Dave Klages has a buddy building in the hangar next to his in Chino.
You should come see your old friends sometimes. Glad your
back! Call me 951-314-0305.
Tom Prokop
Chino, CA
RV-8A,180/CS/Carb, AFS 4500 EFIS/EMS
RV-6, sold, 820 hrs of fun.
Old 12-03-2010, 08:54 PM
Paddy's Avatar
Paddy Paddy is offline
Werner,
I'm building a -10 in Long Beach and would love to meet up with some other local builders. I built the fuse before the wings and am working on the fuel tanks at the moment.
Jim Carey
