Keep VAF
Going
07-01-2022, 06:50 PM
Originally Posted by scsmith
I wonder about introducing some actual damping into this system.
Clean all the parts so bonding is good. Carefully align the leg fairing, duct tape the bottom, pour it full of room temp cure urethane rubber.
Dan Horton
RV-8 SS
Barrett IO-390
07-01-2022, 07:11 PM
The idea of the stiffeners is to eliminate the fore-aft motion if the gear leg as far as is reasonably possible.
With no motion, there can't be damping - damping requires motion to work.
And using an elastomer as a bond agent merely introduces flexibility when that's not desired.
The whole idea of this sort of stiffener is to add a structural element that's integral to the gear leg. Making a mechanism out of it, even a fancy one, is not consistent with that, and by its nature, lets motion occur - it's exactly that motion that's not desired.
Dave
07-01-2022, 08:00 PM
Dave
I still have concerns about this method. Now you have a much stiffer arm and the fore/aft forces are transferred more directly to the engine mount (gear leg mount tubes). The early RV-3 engine mounts cracked because of those forces and the two additional mount to firewall bolts were added. Wouldn't this much stiffer system require additional strengthening of the engine mount? Or was there some other reason those two attachment points were added?
Finn
N214FL RV-4 Mazda 13B Renesis First flight 20 Feb 2021
N46AZ RV-3B Mazda 13B EFI -- Bought -- Flying
N993FL RV-3A Mazda 13B NA 575 hours
07-01-2022, 09:01 PM
Finn
Since I went to the TLAR engineering school and I stayed at a Holiday Inn Express last night, I would think a shimmy leg would be worse stress on the mount than a constant force. As long as the stiffener does not tie in to the fuselage, I dont see any harm. But what do i know, I am getting kicked out of my hotel room due to non payment...
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2022, worth every penny
RV9A- Status:
98% done, 2% left to go
Structure done (less gear)
Electrical/Panel done
Firewall Forward 95% done
Fiberglass 90%
www.pilotjohnsrv9.blogspot.com
07-02-2022, 07:27 AM
Adding the stiffener has no effect upon the forces at the top of the gear leg where it meets the engine mount. But eliminating the shimmy removes that undesirable dynamic load, and that's got to be good.
I watched mtnflyer's video showing his RV-6a main gear shimmying, and found it hard to believe that the gear stayed on.
Dave
07-02-2022, 08:36 AM
Antisplat on the right track.
The video for the nose wheel gets to the heart of the matter. The steel clamp on the MIDDLE of the of the steel rod is the critical ingredient . This is the end game for the Adel Clamp uncertainties. Time may prove Ironflights approach is totally satisfactory. If found to need more coupling security over time, the Antisplat approach might be a potential improvement.
The challenge appears to me to be the fabrication of a clamp that fits the tapered gear leg and does not crawl down the taper. A lot of smart people here, lets solve this problem and end the RV shimmy. Antisplat will probably kit it because the market is much bigger than nose wheels.
PS, anything that absolutely controls the deflection of the gear leg over its distance, Will concentrate the bending moment at the mount as previously challenged. This will creat a new unknown.
Larry DeCamp
RV3B sold
RV-4 fastback in process w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
07-02-2022, 10:24 AM
An afterthought
Using the engine cylinder head bolt preload principal, you could stiffen the rod leg with the backing bar to resist the maxlmum deformation expected ( reasonably practical ) and it should act like RV8 gear if it doesn’t break off at the motor mount
Larry DeCamp
RV3B sold
Clinton, IN
07-02-2022, 10:33 AM
VAF Moderator / Line Boy
Appreciate all the comments guys - and I’ll report back when the whole thing falls apart. But I should point out that I am not the first one to do this - I stole the idea from guys who have been flying with the same thing for years. I’m just giving it some visibility for those that want to try something different, but which has some significant history. And lest you worry, there is a bit of engineering consulting behind it as well.
As for the P-shaped Adel clamps versus a symmetrical design, that’s also a question I have. I might end up fabricating some new clamps in the future, but we’ll fly this for now, and see how it lasts. I know of at least one plane with this design that has been in regular use for over ten years without a problem.
YMMV of course …. This is experimental after all!
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
07-02-2022, 02:54 PM
Alternate
Paul
I think the originator alternated orientation of the P clamps along the leg. Is there any reason to alternate orientation as opposed to all the same way?
John S
RV9A- Status:
Fiberglass 90%
07-02-2022, 07:14 PM
Getting the alum bar centered so it will fit in the gear leg fairing?
Finn
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
