The image of a show airplane is quickly slipping away; maybe for the best. I was feeling so smug about turning the fuselage on its side to finish some interior work and keeping an eye on Smidler as we set some rivets. Then I finally did the inevitable.
Just like that first scratch on your car or the first time you dropped your helmet off the back of the Harley, just do this and get it over with. The damage doesn't show too bad, if its in the right place instead of the side skin. The "learning experience", which this is all about, is to place something between the skin and that nasty tool under the influence of gravity. So find an inconspicuous spot on the airplane and drop that bucking bar. You'll be glad you did.
But before you do, practice you language skills; you don't want to say those words in front of your helper's son.
Ruley
N277PM
"Modified" RV7A fuselage
Lafayette IN
[/IMG]
[/IMG]
Ruley
N277PM
Lafayette IN
