bruceh
I was doing an oil change today, and as usual, I give the entire engine a really good look over. I found one of the exhaust hangers had cracked.
The hanger is made from thinwall stainless steel 3/8" tubing. I know I can source this stuff locally, but making the end flattened looks like it might require some special skills/tools. I don't want to just beat it flat with a hammer. My vise is probably not sufficient to pinch this, and I don't have a hydraulic press.
Any tips, or should I just call Vetterman Exhaust and get a replacement?
Would you replace all hangers, or just the one that is cracked?
