Old 12-13-2020, 05:27 PM
Mike Houston Mike Houston is offline
Default 915is
I would like to see a 2 seater built around thie rotax 915 powerplant bigger and faster than the RV 12. I see a number of 200 mph planes out of europe using this engine. Retractable gear would be nice and a build time of 500-700 hours.
range should be similar to RV14 or more due to the low fuel consumption
Old 02-05-2021, 07:03 PM
CJ in EP CJ in EP is offline
Default How about?
I could really see something like this catching on!
Chris Hrabe
Eden Prairie, MN
RV-9A
Finishing up the little bits and pieces...
Old 02-05-2021, 07:20 PM
David Z David Z is offline
Work the hopper into the fuel system, and you'd have some absolutely ridiculous range and endurance. Assuming that's an 802 and 400lbs/hr fuel burn, that's about 17 hours! Heck it has more fuel than the my day job Dash 8. Although I don't want to pay the fuel bill.
RV-8
Empennage Passed Pre-close Inspection
Wings mostly done
Fuselage started
83126
Dash 8 day job is financing the RV-8
Donation till September 2021
