Keep VAF
Going
09-13-2013, 08:46 AM
Ground Power Unit / Battery Charger
Question, working on my panel what are you guys using to both power the panel while setting functions on Dynon units and also charge the battery? The panel will be in the aircraft along with the battery and all electronics. PC680 battery at 17ah. Thanks, Mark C. 9A
09-13-2013, 09:37 AM
I use the Odyssey battery charger depicted on the left:
http://www.odysseybatteries.com/acce...rgerchoice.htm
Works great.
Don
RV-8 QB Titan ECi 191HP XIO-360
WW200RV Dynon D180 HS34 AP74
GNS430 SL30 GTX327 PS8000B Uavionix Echouat
"Pilots are alchemists... we turn gold into lead."
09-13-2013, 09:57 AM
Don, are you using the OMAX-12A-1B, does the fan running all the time make too much noise? as part of the application do you just leave it on the battery when setting up your panel? Thanks, Mark C.
09-13-2013, 12:21 PM
That's the one.
The fan is very quiet, not silent, but the ringing in my ears is much louder.
You can leave it on all the time as it is a smart charger.
Don
09-13-2013, 07:08 PM
Unless you have a true power supply (not the same thing as a battery charger) then I would just run in on the battery and then charge the battery when you're done with everything off. Battery chargers do not put out a smooth DC voltage.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
09-13-2013, 07:21 PM
Originally Posted by cfiidon
Yep, me too. Same results.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
09-13-2013, 11:45 PM
Terry, is that also how you did your panel setup , run it off the battery and than recharge?? Mark C.
09-14-2013, 07:12 AM
I asked Odyssey about this. They said " do not have the their charger on the battery at the same time that you are using the battery". Something to do with how the Odyssey charger reads required charge. So, work on panel from battery, then recharge.
Personally, I bought a dedicated 13.8 volt, 40 amp power supply. Disconnect the battery cables and powered from that supply source. Powers everything all day long and no second guessing amount of charge left or other battery issues. Plus, power supply comes in handy for dry rub testing stuff on the bench.
Tom H.
Tom Hanaway
Moved to Murphy, NC
RV-10/N518TP-sold
repeat offending-8A N116TP-Now Flying
based in Copperhill, TN 1A3
09-14-2013, 08:16 AM
Where?
Tom, can you supply purchase info?
Could you use alligator clamps and just clamp on downstream
Of the master?
Bert
RV-9A ?Pearl?
Working on Instrument ticket
Donation Done for 2021
09-14-2013, 02:14 PM
Bert,
I used a Samlex America model SEC 1223. 13.8 volt, 23A (not 4O amp) unit.
I connect mine right to the leads-alligator clips-taken off the battery. This allows me to turn off power with master switch at panel, if necessary.
Tom H.
Tom Hanaway
Moved to Murphy, NC
RV-10/N518TP-sold
Thread Tools |
Display Modes |
