Old 07-13-2020, 07:56 AM
scard's Avatar
scard scard is offline
Default CMW E-Lift -- My take on lifting for emergency tire repair
Those of us that travel much have all thought about what we need to fix a flat away from home. Of course we all carry the requisite tools, but lifting the airplane is a tricky part. This is my lift solution for those emergency cases. It isn't appropriate for normal everyday maintenance, and I still use a wing jack in the hangar. There are a lot of ways to skin this cat. I think I've seen most of them, but this is what gives me some piece of mind when far from home at that desolate fuel stop that had the cheapest fuel, but looks like you just landed on the face of the moon without a soul in sight.
It consists of a lift shaft, a steel bracket bolted to U-403 via some new CNC solid aluminum spacers, and a steel foot with a thrust bearing in the bottom. The bracket is plugged, top and bottom, to keep terrestrial gunk out while hopefully never in use.
We've made a number of these to spread around and have a few left from the last batch if you're interested here. This only works on round gear legs that use Vans U-403 brake flange, which means 4, 6/6A, 7/7A, 8A, and 9/9A, refer to Vans drawing C2. Pictured is for tricycle gear and we have a different bracket for conventional gear.
Scott Card
CMW E-Lift
Old 07-13-2020, 08:38 AM
Swoda Swoda is offline
Default E-Lift
Great idea, order placed.
Ron Greene
CWO4, U.S. Navy, Retired
RV-6A N57BZ
RANS S-6ES N75798
Taylorcraft L-2 N55049
Old 07-13-2020, 10:15 AM
kyhunting kyhunting is offline
Ordered a set
David
RV6A, O-320, G3X T
U.S. Navy 83-89
Donated 11/2020
Old 07-13-2020, 06:38 PM
ronschreck's Avatar
ronschreck ronschreck is offline
Default VAF members amaze me!
Very clever. Well done!
Attachment 184
Ron Schreck
IAC National Judge
RV-8, "Miss Izzy", 2250 Hours - Sold
VAF 2021 Donor
Old 07-13-2020, 06:42 PM
Mark Dickens's Avatar
Mark Dickens Mark Dickens is offline
Love it. Simple and effective. Heading to your website now
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
https://www.marksrv8.com
Old 07-13-2020, 07:03 PM
toc pilot toc pilot is offline
Default order
According to your website you are Out of Stock.
Please put me down on your list as 'wanting to purchase' the next time you make a production run.
Bill Hempel
Bill Hempel
RV-7: N17HB AEIO-390, Hartzell Composite C/S prop, Dual Skyview D1000. First Flight: Oct 2017. 2019 dues paid.
https://www.facebook.com/Bill-Hempel...?ref=bookmarks
Old 07-13-2020, 07:44 PM
DJR DJR is offline
Does not work on the 8? Just the 8A correct?
Old 07-13-2020, 07:57 PM
RotaVR RotaVR is offline
Your website states there is plenty of clearance within Vans standard pressure recovery wheel pants. Have you had an opportunity to test fitment with Vans original one piece wheel pant? Thinking RV-4 application. Looks like a great product! Steve
Old 07-13-2020, 08:29 PM
DennisRhodes DennisRhodes is offline
Just an idea but looks like you could thread a short piece of the same threaded rod into the bottom of the axle / flange adapter part and use a floor jack for regular wheel maintenance. The problem with a floor jack has always been no place to support the cradle. But , still great " off the grid" wheel jack idea.
DRRhodes
2020 VAF Supporter
RV9 N908DR
Old 07-13-2020, 09:43 PM
tcard's Avatar
tcard tcard is offline
Correct, it will work on the 8A but not the 8.
We haven't had an opportunity to test fit the E-Lift with an original one piece wheel pant.
CMW E-Lift
The other half of a flying RV-9A and an 8 in the shop.
