Old 11-14-2018, 06:36 AM
Marabou Marabou is offline
Default Bigger main wheels.
Did anybody try bigger main wheels on RV-10? I thoroughly searched forum but did not find a single hint. I searched Desser and Spruce but did not even find tires with bigger outer diameter suitable for 6x6,0 Groove wheels. I see 17.5/625-6 Retread ($100) and the same size Mishelin ($349). As I understand second digit 625 means 6.25 disc width. Van?s supplies 6.0. Is quarter an inch important in this case?
Should I ask Groove?
Unlike simple and straightforward automotive tires aviation tires specification is more confused.
Finish kit is ordered but not shipped yet. It is not too late to delete wheels & brakes and try to fit bigger wheels compatible with Van?s main legs?
Do I miss anything simple and evident?
Thanks for any advice.
And of course I understand that I won't be able to use stock fairing.
Ruslan Bord
RV-7a flying, RV-14a very slowly building
Old 11-14-2018, 07:50 AM
Carl Froehlich's Avatar
Why do you want bigger tires?
Carl
Old 11-14-2018, 08:42 AM
Carl, just flexability. Soft field, gras, etc...
Ruslan Bord
Old 11-14-2018, 08:54 AM
lr172 lr172 is offline
The 10 uses 15/6x6 tires. These are a special,reduced diameter tire. The std 6x6.00 tire will have a larger diameter with a similar weight rating. Width should be similar. Obviously, they will not fit the wheel pants without modifications, if at all.
Old 11-14-2018, 09:03 AM
Ron B. Ron B. is offline
I installed larger tires on my 14A and noticed quite a difference on soft field. The 14 uses 5 inch wheels.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 11-14-2018, 10:08 AM
Ralph Inkster Ralph Inkster is offline
Someone got measurements?
Goodyear charts show 15x6.0-6 at 14.5" diameter inflated (there is a higher speed rated tire at 15.2" also listed). 6.0-6 listed at 17.5" inflated.
Assuming the 120mph rated tire is Vans stock, the space above the tire inside the wheelpant would have to accomodate an extra 1.5" radius to fit a 6.0-6.
Also the hangar door would have to safely clear the tail which would now be about 5" taller.
Ralph
built a few RVs, rebuilt a few more, hot rodded more, & maintained/updated a big bunch more
Old 11-15-2018, 08:06 AM
Jpm757's Avatar
Jpm757 Jpm757 is offline
Regarding the -7, I switched to the 380x150-5 tires and am very pleased with the overall results. Minor enlargement of the wheel pant openings, no noticeable change in speed, much better soft field footprint and better hard surface ground handling. No Brainer upgrade!
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017
(KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis, floats.
Current Project Javron Super Cub
Thank You Doug!
Old 11-15-2018, 09:13 AM
Bill Boyd's Avatar
Bill Boyd Bill Boyd is offline
Don't have time to re-research it right now but I think the Desser Monster retread tires in 15/6x6 are a somewhat larger OD, and I plan on vertically spacing my wheel pants for same, while starting out with the Chinese tires in the kit. Once those are worn, I plan to replace with the Monsters for the hopeful increase in soft field sure-footedness since I will fly 95% off grass, here at home.
Am I correct?
Bill Boyd
Hop-Along Aerodrome (12VA)
RV-6A - N30YD - Built '98 / sold '20
RV-10 - N130YD - 50 hours +
65 years running stock DNA
Old 11-15-2018, 11:16 AM
ppilotmike's Avatar
Am I correct?
Bill,
I talked with Desser at OSH this year (and bought my tires at a show discount). They apparently don't make the "Monster Retreads" for the 10-sized tires. The do make retreads (which is what I bought), but they are not the thicker "Monster " retreads, like they make for the other Vans Aircraft tire sizes. In other words, the thickness of the retreaded rubber is not thicker than the spec calls for. I've still heard that the retreads hold up better and longer than brand new, for some reason, so that's what I bought. They were also cheaper than new. Go figure!
Mike Rettig
VAF Dues Current
RV-10 - Working on engine / prop installation
Old 11-15-2018, 05:00 PM
MConner MConner is offline
I fly off grass and love my bigger tires.
Mark
RV-10
Bought not built
EAA 180
48X
