Old 04-17-2021, 06:31 PM
ExtraKatana's Avatar
ExtraKatana ExtraKatana is offline
Yep. 6 is climbing to 16V and popping the CB. Sense voltage is steady and consistent with the engine not running.
Pulled the teg this evening. Going to BandC Monday.
RV6A
RV7A
RV8
Old 04-17-2021, 06:50 PM
PilotjohnS PilotjohnS is offline
Default schematic
You know, a schematic of the electrical system around the reg and alternator would be helpful. We are all assuming it is what we think it is, but only a schematic would make all our visions correct. You know what they say about assuming....
John S
Dues paid 2021, worth every penny
RV9A- Status:
Tail 98% done
Wings 98% done
Fuselage Kit 98% done
Electrical 85% in work
Firewall Forward 5% in work
Fiberglass 0%, thought i was building in metal?
Old 04-18-2021, 09:38 AM
airguy's Avatar
airguy airguy is offline
I had this same issue last year when my Plane Power died and I replaced it with a B&C - my initial run tests and flight tests, and all the troubleshooting followed yours exactly. Eventually I ended up at the hangar with one of their guys on my phone, and I ran through all his troubleshooting requests with a multimeter with no joy. He said "Send back the regulator and we'll send you a warranty replacement."
I sent it in, they cross-shipped one to me, and I asked them to please let me know if the regulator bench-checked out OK - so that I would know for sure the problem was on my end. I never heard back from them, and the replacement regulator worked perfectly.
Garden City, TX VAF 2021 dues paid
N16GN flying 750 hrs and counting; IO360, SDS, WWRV200, Dynon HDX, IFD440
Old 04-18-2021, 11:24 AM
N49ex N49ex is offline
Default Bus Voltage HIGH
These regulators have a series power transistor from bus to field that is driven to provide the appropriate field current. That transistor is the one mounted on the case, and is a stressed device. When they short out (A common failure mode, which for example can occur by over heating of the transistor) the regulator shoves maximum current into the alternator, which is exactly how this kind of over voltage behavior can occur.
Old 04-24-2021, 10:09 AM
Default Bad regulator
sometimes you just have to bite the bullet and replace something. Installed a new LR3C Dash 14 and a five minute idle has voltage rocksolid at 14.3 V. I guess I’m within that 10% that experienced a problem but didn’t wire it incorrectly. I learned however and thank you for your help.
RV6A
RV7A
RV8
