Old 07-17-2019, 08:56 AM
jcarne's Avatar
jcarne jcarne is offline
I don't know about you guys, maybe someone else that knows more can comment, but on that interior picture it certainly does not look primed to me. I know Van's QB kits come with P60 which is pretty light but I'm just not seeing it.
Jereme Carne
PPL
RV-7A
I can see the light!
Exempt but gladly paying!
Old 07-17-2019, 10:13 AM
fl-mike's Avatar
fl-mike fl-mike is offline
I have a feeling that the storage area had fertilizer or something like that in proximity to the kit parts. The corrosion under the rivet heads and on the spar is concerning. That would be near impossible to correctly address. I would look for a kit in better condition, and add this example to the "primer wars" conversation as an example of "why I prime".
Mike W
Venice, FL
N164WM
Old 07-17-2019, 11:04 AM
Chris7 Chris7 is offline
I would guess that?s the horizontal and not the wing. Also took a few looks for me to understand.
Chris
RV-10.
Emp complete (minus fiberglass)
Wings started
First RV-10 build in Hong Kong
Donation made 2020
Old 07-17-2019, 11:06 AM
jcarne's Avatar
Ah yes, I think your right. Now I see P60 on some of the fuselage parts.
Jereme Carne
PPL
RV-7A
Old 07-17-2019, 01:57 PM
Charles in SC Charles in SC is offline
I looked at the pictures 3 times and the only primer I see is in the picture with the circuit breakers and on the on the elevator push tube. It looks like green something. My -7 QB kit is from 2006 I read somewhere that it should have primer but it did not. I would pass on this one. If you buy it you will be having to convince everyone that ever looks at it that it is ok and you will always have a question in your mind.
RV 7
Old 07-17-2019, 02:42 PM
Vol88 Vol88 is offline
Default Update
I had a chance to take another look yesterday, along with my A&P building partner who inspected everything visually, in detail. Here's some more information.
In spite of what the pictures look like, we saw no rivet heads with corrosion under them (probably light reflecting in the photos), nor did we see any bulging areas anywhere. There is light pitting distributed across the external surface of the parts. So the seller gave us some 1500 wet/dry paper and the pitting disappeared easily, leaving the Alclad intact.
Of more concern to my A&P friend were some dings and scratches that will need to be repaired, and that would give me the chance to get inside a few structures. When one door closes, another one opens...
The light spotty corrosion in one area of both QB wings may be because QB wings come without the bottom skins riveted in, and in this case the builder didn't prime before assembling the last skins.
The area that looks like rust at the bottom of the firewall in one of the photos cleaned up nicely with water and a rag.
I spoke with a person with expertise in light aircraft metallurgy and paint, and he suggested that light corrosion on QB assemblies might be the remnants from the salt air of the Phillipines, exacerbated by being cooped up in a hangar with no circulation for a couple of years, along with the summer heat around here. He also posited that the light corrosion I see is unlikely to progress much once the plane is in an environment with normal circulation and ventilation.
I thought the powder-coated parts were bad until my friend pointed out the torque tube one was attached to. It looked like someone had taunted a Doberman with it. And the Doberman might have been carrying a pipe wrench.
By the way, the zip ties several people have commented on are only keeping the wires from tangling or falling into the wing while it is stored. On the other hand, they'll all need to have new terminations on both ends.
Thanks for all of your observations and opinions. This is just the second time I've posted a question on VAF, but both times I've been impressed with how responsive and helpful my 21,000 or so new aviation friends are.
I hope to meet some more of you at the various RV soirees at KOSH.
Tom
Tom
Drilling out rivets since 8/19
Adopted RV10 in pieces and parts
RV Assembly Workshop - KOSH 2018
Old 11-25-2020, 12:54 PM
Default Update
To close the loop on this thread, I purchased this unfinished kit in August 2019. Many thanks to those who responded with opinions and expert advice. I admit I was swayed most by the responses from those - like Vlad - who could speak to the difference between unpainted aluminum and corroded aluminum. I most appreciated the time that Vic Syracuse graciously spent with me in between two of his presentations at AirVenture 2019, looking at closeups of pits, rivets and dings, and suggesting how to structure the purchase, given a brand-new, out-of-warranty engine.
Why close the loop now? Our hostís reminder about contributions reminded me that, if I hadn't been part of VAF, I would not have known to contact Vic, so I'm sending a small honorarium to DR in Vic's honor, over and above my annual contribution.
By the way, Iíve been through much of this kit in detail - including rebuilding a part of the tail cone - and Iíve seen virtually no corrosion on the unprimed Alclad faying surfaces. If Iím still living in the Midwest when I build my next plane, Iíll probably skip the primer on Alclad surfaces.
Tom
Old 11-25-2020, 01:20 PM
lr172 lr172 is offline
Glad to hear it worked out. I also bought a previously started kit. I am in Schaumburg and finished my 10 last December. Feel free to reach out if you need help or want to see a finished example.
Larry
Old 11-26-2020, 04:51 AM
FlyinTiger FlyinTiger is offline
Thumbs up QB wash primer
For those concerned about not "seeing" the primer inside QB kits I too was a little concerned since they are advertised as having been primed. After calling Vans to chat they told me the primer is applied without the pigment so it is clear. Also as a "wash primer" it is not nearly as robust as those two part epoxy primer coats, but that as a result it is much lighter. A compromise of sorts...
I bought a -7 that was assembled with a QB fuse and wings so my research during that process was extensive. I'm glad the OP is happily working on his new project and will get another one of those kits sitting idle into the air.
Best of luck to all the builders this season!
AL
Launching from SC45
Old 11-27-2020, 08:18 AM
Thanks Larry. Iím the guy that took your fuse cradle, and appreciate it every time I work on the plane. I also saw your -10 at KDPA when you were starting your Phase 1.
There will be a fleet of 10s in the western suburbs in another year or two.
Tom
