Old 06-04-2022, 12:22 AM
Reaver Reaver is offline
Default Monitoring P-mags with Dynon Skyview
Does anyone know if the Dynon Skyview has the ability to monitor anything (other than tach) coming off of P-mags, similar to say an EI Commander? Is there any benefit to wiring up the TX/RX ports from the P-mags to the Dynon EMS-220 or similar?
2005 RV9
2022 VAF dues paid!
Old 06-04-2022, 07:18 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Unless there has been a recent software update that I don’t know about…no. I have talked with programmers from all of the EFIS manufactures about P-Mag data display, and most have said “they’d look into it”, but none have done anything yet. I chatted most recently with Greg from GRT about it at SnF, and he seemed interested - but we’ll see.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 06-04-2022, 07:45 AM
Pdtofly Pdtofly is offline
Default P-Mag temps
I went an added a couple thermocouple probes to display the P-Mag case temps.
General Purpose Thermocouple
You may configure the SV-EMS-220 to monitor two J or K type thermocouples in addition to the twelve thermocouples available on the SV-EMS-220's D25 connector. Note that the SV-EMS-221 uses these four pins for Rotax 912 is communication, and, therefore, these pins are not available for thermocouple use on the SV-EMS-221. Dynon Avionics does not supply a specific general purpose thermocouple sensor for this purpose. However, our standard EGT and CHT sensors will work, as will any other J or K type thermocouple. They go into pins 27, 28, 36, and 37.
I programmed the EMS, and put a couple widgets on my screen. I didn’t get a chance to fly my plane yet and see what it displays in flight, but will later next week. I just stuck them on next to the temp sticker.
This is what I got. https://www.iothrifty.com/products/t...14364329574442
Click image for larger version
Brian
Old 06-04-2022, 09:10 AM
derLuigi's Avatar
derLuigi derLuigi is offline
Default engingebridge
Hi Reaver,
you might want to look into a product called enginebridge (I've got no affiliation with them except being a potential customer once I reach that state):
https://www.enginebridge.com/product/eiwifi/
It can send out information about advance angle, temperature and dwell times as a 0-5 V signal which can be connected to analog inputs of the EFIS. What I'm not yet sure about is how many extra analog inputs the skyview system has available.
One thing the EI Commander does but the enginebridge unit can't is checking for "timing divergence" (basically measuring if both P-Mags are firing in sync).
Mario from Frankenberg, Germany
RV-7, emp. done, wings close to being ready for inspection, canoe flipped and parts of the finish kit in just about every room of the house
2022 contribution sent - thanks for this awesome space DR
Old 06-04-2022, 06:31 PM
drill_and_buck's Avatar
drill_and_buck drill_and_buck is offline
What do you plan to do at annual when you need to pull the PMAG for inspection?
Mike Draper
RV-8 N468RV
First Flight 11/13/2011
TMX0360, Dual Pmags, CS
