Keep VAF
Going
12-28-2021, 03:33 PM
Looking for some info on Lasar ignition system
Hello everyone!
Merry Christmas!
I got some serviceable (removed from flying airplane with Lycoming IO540) Lasar Electronic Ignition model LC-1A11-15 with two Slicks 6770 and 6776. While knowing that this is an old and no longer reasonably supported system I want to little dig in to it and see what can be done with it for my RV10 project.
I am looking for any documentation you may share for this system as I have no documents at all. I am interested in manual, connection diagrams, etc. Separately I want to figure about timing advance adjustment as it may require additional equipment (but I think it can be done without if proper schematic diagram is available).
Thank you!
Vlad
Vlad Milos
RV10 (#42078)(C-FFVX) - Started my build on Oct 31, 2019
Working on Firewall Forward (June 04, 2022)
RV10 (#42756) - Empennage kit on order (Feb, 2022)
My RV10 Build Vlog
My Instagram
12-28-2021, 03:42 PM
Senior Curmudgeon
Vlad, send me your email via a PM.
I have a PDF of the lasar manual I can send to you.
As far as I know, one of the only places left to work on Lasar is AeroSport Power in Kamloops BC.
Yes, it does take a specific tool for setting the timing.
I have a complete system with a bad sensor mag if you are interested in getting spare parts. Includes the timing tool.
If you can get hold of him, Joe Louge at Champion is the best knowledge base on Lasar, pretty sure he was in on the development of the system.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
12-28-2021, 04:57 PM
Hi Mike,
Thank you for your reply. Will PM you in a moment!
Vlad Milos
My RV10 Build Vlog
My Instagram
12-28-2021, 06:45 PM
Just a note for Mike. Joe Logie retired and was no longer at Champion. I found out at AirVenture 2021 when he as not at the booth.
Gary A. Sobek
NC25 RV-6 Flying
3,500+ hours
Where is N157GS
Building RV-8 S/N: 80012
05-25-2022, 10:01 AM
Mike,
Do you have a T-300 Tool ?
05-25-2022, 03:40 PM
Senior Curmudgeon
Originally Posted by AlexM
Mike,
I have to check what the number is on the tool.
Not sure if 4 and 6 cylinder setups used the same timing tool.
Mike Starkey
VAF 909
Rv-10, N210LM.
05-26-2022, 12:42 AM
Thanks ! I will stand by
05-26-2022, 08:22 AM
LASAR timing tool
Pretty sure the LASAR T-300 timing tool works for both 4 and 6 cylinder engines. It is only looking for TDC (cylinder 1) and points open/close positions during crankshaft rotation. It doesn’t know or care about the number of cylinders. Also, the T-300 is the only timing tool mentioned in any of the LASAR docs.
Steve Allison
RV-6A - sloooowwww build
First flight - 3/8/14
Phase II - 5/19/14
Thread Tools |
Display Modes |
