Keep VAF
Going
04-30-2020, 04:56 PM
Custom Stick Grips
I had this idea to make my own stick grips. This is what I came up with. Wife says they look retro...
PTT in the back.
Steve S.
Rebuilt RV6A Flying!
Scio, OR
EAA Ch. 292
04-30-2020, 05:27 PM
That's the best of the homebrew stick grips I've seen so far. Good job!
Dave
04-30-2020, 06:12 PM
gotta love the HAAS machine in the background!
Tom
RV7A Tail Kit Completed, Fuse started-Pay as I go Plan, on hold while we develop new products for RV builders
Ridgeland, SC
05-01-2020, 04:07 AM
Huh?
A smoke switch that you have to hold down just doesn't make any sense to me. I'm open to other opinions but it had better be good.
05-01-2020, 07:31 AM
You know, I cooked up a little switch control for just that kind of thing. A single tap toggles the output (smoke or whatever you please) on or off. Hold it down for more than half a second or so, and it will turn the output on until you release it, then turn it off. Seems like it would be be easy and intuitive to use. I personally don't have a use case for it right now, but I did breadboard the thing and it worked. Wouldn't take much to solder up a few prototypes.
Dale
Omaha, NE
Previous RV-7 project (sold)
05-01-2020, 07:43 AM
Dale, I looked at that relay too. (Press on, press-off) but just decided to put a switch on the panel for the smoke to stay on, if desired. I don’t do aerobatics. I just wanted to be able to output a bit of smoke on occasion. Also I have a indicator light for smoke on.
Steve S.
Scio, OR
EAA Ch. 292
05-01-2020, 07:45 AM
I like that! You should also wire a "smoke on" light in parallel with the smoke pump to confirm that the smoke is on or off. Looking behind you is not an option in close formation.
05-01-2020, 08:11 AM
Originally Posted by Zero4Zulu
Dale, I looked at that relay too. (Press on, press-off) but just decided to put a switch on the panel for the smoke to stay on, if desired. I don?t do aerobatics. I just wanted to be able to output a bit of smoke on occasion. Also I have a indicator light for smoke on.
I'm not talking about something that is currently available, it's something I have cooked up on my own. Not just push-on/push-off. A fully custom solution that gives you a single pushbutton switch that allows use either way without the need for anything else.
Dale
Omaha, NE
05-02-2020, 08:35 AM
Agree: This switch should be a click on-click off with smoke-on light installed in parallel with the power lead and the light in your line of sight. It would be difficult to fly close formation attempting to hold the button down for a smoke on.
05-02-2020, 09:33 PM
Nice!
Very nice work!
PTT in the back.
Mark Burns
Ruston, Louisiana
RV-7A N781CM 1,700+ hrs
FFI FL-24
A&P
Thread Tools |
Display Modes |
