Having put off joining the fuselage halves until I finally could have a helper ....
Is there guidance in the KAI for routing the above items through the main fuselage? If there is I still can't find it.
The routing seems pretty straightforward - both run from the aft fuselage forward on the right side, one rib bay out from the central bay. Between the flaps tube and the spar, route into the center area through the bushing clip then straight ahead through the wing spar and up the central ramp alongside the forward fuel line.
Please let me know if any of this is incorrect. Thanks!
