Keep VAF
Going
VAF on Twitter:
@VansAirForceNet
04-07-2021, 07:26 PM
Filling Fuel Tank Rib Tooling Holes - Question
Hi everyone,
I'm working on my fuel tanks for my 14A and have what is probably a dumb question, but i searched and didn't come up with anything.
The fuel tank ribs have two tooling holes each, and the plans say to fill these with 3/16 rivets. All of the ribs have these holes, and the plans say to fill them all in. I'm assuming that only the inboard and outboard ribs need to have these holes filled, correct? I can't think of a reason why the inboard ribs would need to be filled since they are internal to the tank, but maybe there is a reason I'm not thinking of. Wanted to check before I install the ribs and then find out I have to plug these holes while they are in place. Thanks!
Parker, CO
RV-14A Under Construction
Empennage Kit arrived on 10/11/19.
Vertical Stabilizer DONE
Rudder DONE
Began Horizontal Stabilizer 01/28/20.
Horizontal Stabilizer DONE
Started Elevators on 02/24/20.
Elevators DONE
Tailcone DONE
Wing kit arrived on 7/30/20.
Began wing kit on 8/4/20.
Donated: 2021
04-07-2021, 07:34 PM
On my RV-7, the outboard rib was the only tooling hole that needed some sort of cover or 3/16 rivet (builders choice). The inboard rib tooling hole ended up getting covered by doubler ring and access panel. I left all inboard ribs alone. Can't imagine why the 14 would need inboard rib tooling holes closed up.
Vintage Cherokee 160
RV-7:
Empennage complete
SB Wings to QB stage
Fuselage in progress
04-07-2021, 07:37 PM
Thanks for the reply, that was my thought as well. The 14 actually doesn't have the access panel in the rib like other models, so the inboard rib has to have the holes plugged as well.
I'll go with just the inboard and outboard ribs and leave the inboard ribs as they are. Will save me a few minutes of time. Thanks!
Parker, CO
Rudder DONE
Elevators DONE
Tailcone DONE
Donated: 2021
04-07-2021, 10:04 PM
Old school mod
I am not sure about the RV14, but on my RV9, I enlarged the tooling holes on the ribs inside the fuel tank to help with filling the tanks. Something to consider.
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2023, worth every penny
RV9A- Status:
98% done, 2% left to go
To Go: wing mounting, engine baffles, wing tips, move to airport
www.pilotjohnsrv9.blogspot.com
04-07-2021, 11:42 PM
Thanks John, I will take that into consideration. I am planning on installing the ribs in the first tank tomorrow, so I will need to decide quickly. I'm following your build by the way....very inspiring!
Parker, CO
Rudder DONE
Elevators DONE
Tailcone DONE
Donated: 2021
04-11-2021, 02:08 PM
I think the confusion is that the instructions do NOT mention the 1004 ribs which are all the "other ribs" There's a lot of gotcha's like this where you need to identify all parts sometimes on different pages to get full understanding of a set of directions.
So you only seal the outboard ribs in this case.
Step 7: The T-1003C-L & -R Tank Inboard Ribs-Fwd, T-1003B-R & -L Tank Inboard Ribs-Aft, and T-1003-L
& -R Tank Outboard Ribs each have two .188 [4.8 mm] diameter holes. These holes are used to hold the
ribs in proper alignment with the tool during hydropress forming of the ribs.
I added this thread to the WIKI (see signature)
Pete
RV14A Tail kit 95%
Wing kit 95%
Fuselage QB in progress... finally delivered 18months late
RV 14 WIKI in Drop Box
https://www.dropbox.com/sh/xu5p6f4l7...bU0ck0pJa?dl=0
---For Edit Access drop me a PM with your Email address.
EAA 1300
Donation Paid 18,19,20,21 Military exempt
12-13-2021, 04:00 PM
Btw i am at this point and could not find the 426 6.xx rivets to fill this hole. Did i miss it?
RV-7A builder
A320 Capt at some airline
T-37/T-38/KC-135
C-177/172
Piper Warrior
2023 donator
Emp complete
Wings complete
Working on fuselage
12-13-2021, 04:16 PM
May not want to do this for tanks on an aerobatic RV.
Carl
12-14-2021, 06:54 AM
The 14 fills adequately and does not need additional / enlarged holes for fueling.
Dennis Callaghan (X26)
- RV14 sn:140193 - Awesome airplane!
- donation 11/17/2022
12-14-2021, 09:49 AM
Van's didn't supply any rivet larger than 1/8" in my kit. Its up to you to procure the 3/16" rivet if that's how you want to close the hole. I made a small plate held on with four NAS1097 rivets. Seems counter intuitive to drill 4 new holes to cover 1 hole, but it worked.
RV-7:
Empennage complete
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
