Old 08-25-2022, 05:54 AM
prkaye prkaye is offline
Default two radios through same PTT?
Hello,
If I wire two independent com radios (no audio panel) through the same PTT switch, is this likely to cause any problems (weird ground loops etc)?
Thanks!
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 08-25-2022, 06:07 AM
RV6_flyer's Avatar
20+ years ago, I added a 2nd radio without an audio panel. The PTT switch was run through a DPDT switch that selected com1 or com2 for the PTT and audio in between the two radios. The switch was located just to the left of the bottom of the top and top of the bottom radio and labeled as Com1 / Com2.
Gary A. Sobek
NC25 RV-6
Flying
3,500+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 08-25-2022, 06:51 AM
Thanks Gary, that sounds like a much more elegant solution than what I was thinking of doing. Would you be able to send me a diagram or sketch of how you wired this? I'm having trouble visualizing how the headphone, mic and PTT circuits for the two radios would be wired through a single switch.
Philkaye@live.ca
Thanks!
Phil
RV9A (SB)
Ottawa, Canada
Old 08-25-2022, 07:12 AM
vlittle's Avatar
vlittle vlittle is offline
On this page, the AMX-2A Install Guide shows an example of how to connect two radios to one intercom: https://www.huvver.tech/open-source-hardware/
Cheers, Vern
V e r n. ====
RV-9A complete
Harmon Rocket complete
Part of EAA award-winning OnSpeed team
The VV in huVVer.tech
Victoria, BC (Summer)
Chandler, Az (Winter)
Old 08-25-2022, 07:14 AM
Freemasm Freemasm is offline
Default Something different than vintage?
PTTs were (are?) simply a ground on the mic jack tip IIRC. You could have a infinite number of PTT switches/circuits provide the ground path for that function.
Sounds like you’re talking a different approach. Any details you can share would be appreciated.
Old 08-25-2022, 07:19 AM
Auburntsts's Avatar
He's talking multiple radios through the same PTT--not the same issue as having multiple PTTs
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 08-25-2022, 07:23 AM
Yes, what i'm doing may be a bit unusual. I have COM radios, with no audio panel and no external intercom. My primary COM radio has an internal two-place intercom. My secondary radio is a backup only and will only be connected to single-place pilot headset. The two radios will never be used simultaneously. In the event of primary com failure, i'd like to be able to throw a single switch and have my pilot-side headset and PTT change-over to the backup COM. Can this be done in a simple way?
Phil
RV9A (SB)
Ottawa, Canada
Old 08-25-2022, 08:21 AM
blaplante blaplante is offline
Is there some reason you wish to avoid an audio panel?
RV6A in phase 2 as of April 2016
Donation made Oct 2021
Old 08-25-2022, 08:30 AM
Mikeyb Mikeyb is offline
A DPDT switch will do this nicely
Mike
Edit
Maybe not. I did not think this through and ignored the audio switching.
Mike
N36MB
SN 83764
IO360-M1B
Hartzell Composite CS
Flying Phase 1
KAJO
Old 08-25-2022, 10:05 AM
RV6_flyer's Avatar
Mike
What you labeled as "pwr" I used "audio in" signal.
Gary A. Sobek
NC25 RV-6
Flying
3,500+ hours
Where is N157GS
