Go Back   VAF Forums > The Never Ending Debate Section > Painting your RV
Old 05-17-2022, 04:53 PM
gttice gttice is offline
Default What are folks using for "smiley" filler
Based on my search results, either I am terrible at finding the right search term or I am the only person to have ever created a smiley that needs to be covered up. But in case there is anyone out there that has used a filler for other kinds of dings, I would love to know what you think are the better ones.
Jerry T.
Old 05-17-2022, 04:57 PM
wirejock's Avatar
wirejock wirejock is offline
Default Filler
Depends on why and where.
I've plugged holes in pull rivets with JB Weld for cosmetic purposes. I've covered or repaired other spots with flox. Never tried to fill a smiley because I don't make mistakes!
Joking of course. If the smiley is on the aluminum and will be painted, I would use auto glazing compound. Sands flat really easy. High build primer would probably fill easily. You may need to sand the smiled first. There's usually a raised area. Not sure how I would know that!
Larry Larson
Estes Park, CO
E-mail: wirejock at yahoo dot com
Builder Blog: http://wirejockrv7a.blogspot.com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved
Disclaimer
Old 05-17-2022, 05:31 PM
Foghorn's Avatar
Foghorn Foghorn is offline
Jerry,
Donít search on the forum. Youíll never find anything. Instead use your favorite search engine, I prefer DuckDuckGo. Type in what youíre looking for followed by ďsite:vansairforce.netĒ. Youíll find all the threads that way.
Example: smiley filler site:vansairforce.net
I used rage gold on the smileys that were bad enough for filler. Thankfully just a few spots.
Good luck
Jeff Parker
RV8 Fastback (Tomís Dream) - Phase II (N767TS)
C195 (Red Dawg) - Flying (N4469C)
Retired Army CW4 - Helicopters, KingAirs, B737, MD11
Old 05-17-2022, 05:43 PM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Use this
Most "smiley's" are pretty small. Scuff them with 320 paper, clean with alcohol. I personally use Evercoat 416 glazing compound for any small fills and finish fill. Hard yet sands like balsa wood. (I didn't have any mistakes on my second 7)
General rule of thumb, anything with a depth of 1/16" or more should be micro filler and epoxy. 1/16th or less, Rage or 416.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717AZ Painted and Complete
2021 Outstanding Workmanship Sun N' Fun
2021 Gold Lindy Grand Champion Kit Plane
2022 Copperstate Fly in Grand Champion/Best Metal
2022 Reserve Grand Champion Sun N' Fun
Old 05-17-2022, 07:29 PM
Stoo Stoo is offline
I prefer to use Superfil which is an epoxy filler. I think this is more stable over the long term. Polyester fillers tend to shrink.
Stewart Willoughby, 6
Old 05-17-2022, 08:47 PM
Bandera Bandera is offline
For bigger dings like a hail dent I like Evercoat Rage or Rage Gold. For smaller dings or scratches I like Evercoat 417. After sanding the filler I prime the spot with PPG K36 primer.
Old 05-18-2022, 03:45 AM
wilddog wilddog is offline
Epoxy and micro. Mix it thick and sand aluminum first. Sticks well, doesnít shrink and sands easily.
Old 05-18-2022, 04:57 AM
Larry DeCamp Larry DeCamp is offline
Smile Adhesion ?
Sometimes west 105 micro can be popped off when cleaning up where you donít want it. I am at this point in paint prep as discussed above.
You are saying purposful sanding is good enough for the micro bond. I was wondering if light etch primer after sanding the aluminum would add anything to the bond ?
Larry DeCamp
RV3B sold
RV-4 fastback in process w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 05-18-2022, 07:54 AM
PhatRV PhatRV is offline
I find that my epoxy/micro mixture makes a better bond if the aluminum is etched and alodine.
RV8 (N38PV): 90% completed (90% to go)
Short List for Hangar !
Days to Final Installation: 999
Days to AWC: 999
Days to First Flight: 999
Painting: 85% completed
Donation paid through 2022
Old 05-18-2022, 06:28 PM
RV7Guy's Avatar
Default Not Catalyzed
Catalyzed fillers don't shrink. Something like Stanton in the tub will shrink.
Epoxy and micro works but difficult to get that perfect feathering blend. The 416 works great for this.
Darwin N. Barrie
Chandler AZ
www.JDair.com
