Old 06-17-2017, 09:49 AM
spatsch spatsch is offline
Originally Posted by sandifer View Post
Hey Oliver, simplify your life like all us Pitts S-1 pilots do.
You mean add a second wing for drag ?
Now that would be an interesting mod on an RV-8.... .
Oliver
Oliver Spatscheck
RV-8 N-2EQ -- flying 500+ hours
Fokker DR-1 N-22EQ -- under construction
http://www.spatscheck.com/oliver
Old 06-17-2017, 10:54 AM
sandifer sandifer is offline
No, that's not simpler, just way cooler.
I meant ignoring the tach.
Old 06-17-2017, 11:32 AM
Well it does make one wonder what the real max RPM on a Lycoming engine is if one listens to certain one designs (more so then S1s) on a downline.
However, that wasn't my point. My point was that for a sportsman routine with a fixed pitch prop in an RV-8 one can be within the RPM limits at all times with very little effort... .
Oliver
Oliver Spatscheck
Old 06-18-2017, 12:27 AM
Naigool Naigool is offline
Default Harness
I'm just curious on which Harness have you installed on your aircraft?
As you are performing negative G , have you installed full aerobatics double harness?
I'm building a RV7 and doing Brainstorming on what to install... ( flop tube, inverted oil system, Harness ... )
Also the lock system is on purpose( standard latch or cam lock)
Any experience welcome!
Old 06-18-2017, 04:25 AM
ronschreck's Avatar
ronschreck ronschreck is offline
I have a Hooker 5-point harness with cam lock. My second seat belt is ratcheting. The ratcheting seat belt probably isn't necessary for recreational aerobatics but sure makes it easier in competition.
Ron Schreck
RV-8, "Miss Izzy", 2250 Hours- Sold
My Aerobatic Video
My Formation Video
CAF B-25 pilot - Airbase Arizona
VAF 2022 Donor
