dougweil
Hi all:
Has anyone had any oil leak issues with the Hartzell prop governor S-1-10? I have about 830 hours on mine and I have had it in our local prop shop (Maxwell Aircraft) twice (350 and 650 hrs) to correct a stubborn oil leak at the rear of the governor. It is now leaking again and I'm about have this repaired a third time. Each time two $3 O-rings are replaced which seems to solve the problem for 300 hours or so.
Any thoughts??????
Any thoughts??????
