Old 06-16-2017, 01:50 PM
jthocker's Avatar
jthocker jthocker is offline
Default Inverted Flop tubes
A data point for anyone considering fuel tank flop tubes.
Decided to see how long my engine would run while inverted and on the NON inverted tank.
I have a flop tube in the right tank and a standard pickup in the left. From "experience" I've noticed I can fly for quite some time inverted and on the wrong tank!
Today, I decided to find out just how long! With only 4 gallons in the left tank and the left tank selected, I rolled inverted and started a timer. At 25 seconds I rolled upright and at the 30 second mark the engine stumbled for about 2 to 3 seconds then it smoothly regained power.
Hope this will convince guys to bite the bullet and install that inverted oil system. There is absolutely no need to put in a flop tube unless you intend to fly inverted for more than 20 seconds.
Jon Thocker
Habitual Offender
RV4, RV4, RV6A, RV8, RV8, RV8,RV8, RV8, RV8, RV12
Old 06-16-2017, 07:06 PM
merlin3 merlin3 is offline
Awesome news! I just need fuel injection as well : (
Justin
Rv-6, o360, whirlwind cs prop, old paint and panel
Rv-4,o-320,prince prop, mgl avionics screens - sold
Old 06-16-2017, 07:31 PM
scrollF4's Avatar
scrollF4 scrollF4 is offline
Moderator, Asst. Line Boy
....and a zero/negative G oil system?
Scroll
Exemption waived.
Proud and grateful 2022 -=VAF=- Contributor
PS: I am not an influencer. I have no influence. Just ask my kids.
Old 06-16-2017, 09:06 PM
KatanaPilot KatanaPilot is offline
Default 12 hours too late
Completed the retrofit of the QB left tank with a flop tube on our RV-7A project just before noon today.
Already converted the O-360 to IO and have the Christen inverted oil system ready to install.
Good to know we will be able to fly inverted for more than 20 seconds. Thanks for the test flight
Krea Ellis
Locust Grove, GA
DA20-A1 "Princess Amelia" - gone home to Amelia Island
RV-7A Phase 2 (Honored to be Van's "Miss July" 2021)
RV-10ER officially an airplane as of 4/5/22!
Old 06-17-2017, 12:59 AM
CubedRoot's Avatar
CubedRoot CubedRoot is offline
I just received my wing kit, and I ordered a flop tube, but also two normal pickup assemblies as well.
I am still going back and forth on whether I want to install a flop tube. I am not sure I will be going inverted for more than 30 seconds, and I plan on doing a simple inverted oil system (probably one of the accumulators) so that's only going to give me about 30 seconds of engine oil pressure anyways.
I am not a big fan of putting the fuel pickup in the inner bay and attaching it to the tank baffle. It won't be easy to service if I ever need to get at it.
I am also considering installing a set of capacitive senders (already got the kit) in addition to the normal pickups so the above may be a mute point.
Lynn Dixon
RV-7 Slider -
Tail kit Completed - March 2017
Wing Kit Started - June 2017
My Build Log: http://www.theskunkwerx.com
Old 06-17-2017, 04:22 AM
ronschreck's Avatar
ronschreck ronschreck is offline
I have the same results as Jon when flying inverted. I get about twenty seconds of engine run when inverted using the tank with the normal fuel pickup. I flew with only an oil accumulator for awhile and found that my 1.5 quart accumulator only gives me about 7 seconds of oil pressure. If you want 30 seconds you had best go with a full Raven or Christen system. I think installing both float and capacitive senders is a bit of overkill. If you have a flow measuring system (red cube) that will be your best indicator. Only a suggestion. You do what you want. I do have a flop tube and full inverted oil so I can fly inverted to my heart's content. My heart runs out of contentment after about 20 seconds these days.
Note: If you are doing competitive aerobatics there are no maneuvers in the Primary or Sportsman sequences that require more than about 4 seconds of inverted flight.
Ron Schreck
RV-8, "Miss Izzy", 2250 Hours- Sold
My Aerobatic Video
My Formation Video
CAF B-25 pilot - Airbase Arizona
VAF 2022 Donor
Old 06-17-2017, 04:28 AM
WillyEyeBall's Avatar
WillyEyeBall WillyEyeBall is offline
Thumbs up occassional sputter
Have a flop tube in one tank, and Jon is correct that you can get extended flight time inverted on the wrong tank. However, there are certain maneuvers, such as a Cuban 8, with several seconds inverted and negative Gs that might give you a short engine stumble. Typically, I can go through the Sportsman sequences on the wrong tank and not get a stumble. With the Intermediate sequence, which has a Cuban 8 without the half roll, and pushed to inverted level flight- BIG STUMBLE. Still not a big deal. Engine completely stopped only twice so far. Still looking to see more RVs come join the fun of competition.
Bill McLean
RV-4 slider
lower AL
Old 06-17-2017, 08:24 AM
spatsch spatsch is offline
lower AL
Just want to second this.
I have no flop tube and no inverted oil. Have been practicing the Sportsman for a while and flew my first Sportsman contest last month. I never had a stumble during the routine and oil pressure is above Lycoming minimums during the entire routine.
There is really no reason for anything special to participate at the Sportsman level. I did eventually install an 1/2 inverted oil system (breather tube only) but not because I was worried to break something without it I just got tiered of scooping substantial amounts of oil of the hanger floor. If you look at it just from a $ perspective would still be cheaper to just add oil .... .
Other thing I "modified" is the break fluid plug (I have two directly on the pedals) as they would leak over my shoes.. . That was a 2$ fix.
Also from an engine perspective I kept it simple I have an IO-360 with the Van's recommended fixed pitch Sensenich prop. Sometimes I sit there and get propeller envy looking at some of the other airplanes at the contest but then I get honest with myself and realize that my score would not have improved a bit with a better propeller.... . There is really no routine in the Sportsman you couldn't score a 10 on with a fixed pitch prop. You have plenty of energy and altitude for that routine without all you have to do is watch your RPMs on a few straight downlines. It's all me... .
I guess what I am saying is that a lot of people overthink this thing. A stock RV-8 is good enough for a Sportsman context.
Don't get me wrong if you enjoy adding gadget to your airplane please do, however, if you are held back from flying contests because you think your RV isn't ready I think you are wrong.
Oliver
Oliver Spatscheck
RV-8 N-2EQ -- flying 500+ hours
Fokker DR-1 N-22EQ -- under construction
http://www.spatscheck.com/oliver
Old 06-17-2017, 08:29 AM
ronschreck's Avatar
Oliver
+1
Absolutely! Of all the mods one can do to prepare for aerobatic competition, a constant speed prop would be my last choice. Keep it simple and you will still have lots of fun and score well, too!
Ron Schreck
My Aerobatic Video
My Formation Video
VAF 2022 Donor
Old 06-17-2017, 09:24 AM
sandifer sandifer is offline
Hey Oliver, simplify your life like all us Pitts S-1 pilots do.
