Old 12-07-2020, 03:54 PM
revenson's Avatar
revenson revenson is offline
Yup, every flight.
Roger, 7A, N374RS, Tucson
Old 12-07-2020, 04:01 PM
rleffler's Avatar
rleffler rleffler is offline
I installed aprs over eight years ago and itís still going strong.
It does a better job at providing flight route maps. This is primarily due to line of sight issues with adsb ground stations if youíre below 3k locally.
ADSB is much more responsive if youíre high enough to send data to ground stations.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 12-07-2020, 05:39 PM
Dvalcik's Avatar
Dvalcik Dvalcik is offline
Originally Posted by MS19087 View Post
I had an APRS unit installed on my last plane and really liked the functionality and ability to give my loved ones insight to my travels. With the aviation specific tracking sites now dark and ADS-B position info available through Flight Aware is anyone still using their airborne APRS trackers?
Yes in still broadcast, Mark I have an extra unit if you need one for the new bird.
David
EAA 1250 KPTW
Royersford, PA
david@rv12pilot.com
2021 VAF Supporter
RV12 #568 EAB
* Started 9/30/2011
* 1st flight 8/30/12
http://www.rv12pilot.com
Old 12-07-2020, 10:00 PM
erich weaver's Avatar
I have ADSB-in/out, received a clean FAA performance report report on it after installation a few years back, and it continues to provide good traffic reports to my GRT EFIS. I fly out of Santa Ynez (KIZA) every week but I see nothing or next to nothing for flight history on the various flight tracking services, at least the free versions. What am I missing? Iím N2725R if someone cares to check for me.
Erich
Old 12-07-2020, 10:08 PM
SPX SPX is offline
Erich
Erich-
Have you run a recent performance report (ADS-B)? If not, give it a try and see if it's still showing good for you. FlightAware really should be picking you up...
Paid, Jan 2021
Old 12-08-2020, 08:25 AM
Sam Buchanan's Avatar
been here awhile
Just for clarification...this thread is about APRS, not ADS-B.
APRS is a system based on the 2M Ham radio band and has no connection with anything FAA-related.
Sam Buchanan
RV-6
Fokker D.VII replica
Old 12-08-2020, 12:03 PM
Dvalcik's Avatar
Erich
Erich this thread is about APRS - but what are you using for ADSB? Echo and GRT, if so contact me their may be a simple fix. I had a problem passing the FAA but not recognized - there is a possible setting you do not have in your GRT if you have the ECHO.
David
EAA 1250 KPTW
Royersford, PA
david@rv12pilot.com
2021 VAF Supporter
RV12 #568 EAB
* Started 9/30/2011
Old 12-08-2020, 05:23 PM
Yes, I have the Echo GRT combo. Thanks, I will contact you David. Sorry for the thread drift.
Erich
Old 12-08-2020, 06:05 PM
John RV8 John RV8 is offline
Yep! I use my APRS every flight, And Yes I have ADS-B out/in also.
John Goodloe
RV-8. N6279G
Pay in November
Old 12-08-2020, 06:29 PM
94kb 94kb is offline
Unhappy Track comparison
I have both aprs and adsb uat in the 4. I have a flight aware adsb uat receiver to send reports to flight aware. I get much better coverage with flight aware than with aprs and additionally get altitude data. The difference can be seen on the following tracks from the same flight.
https://aprs.fi/#!call=a%2FWY0S-1&ti...6400&tail=3600
https://flightaware.com/live/flight/...421205-adhoc-0
Kenneth Beene / Waco, Texas
RV-4 N63KB low wing
J-3 N2263M high wing
AS1 N777PJ bi wing
Cherokee N4217J
APRS WY0S
