  #11
Old 02-04-2021, 03:11 PM
JDA_BTR JDA_BTR is online now
Good tips. I use the G3X knobs for those mainly. I do use the thumbwheel to set climb rate after takeoff forgot about that.
Ser 140142, RV-14A flying - N1463
Ser 83825, RV-8 building - N8638?
USN Ret, Urologist, AME, Repeat Offender
Old 02-09-2021, 07:31 AM
YvesCH YvesCH is offline
Originally Posted by JDA_BTR View Post
I'm looking ahead to where I'll mount things in my -8.
The question I have is how much can go under the seats instead of behind the panel and how is that best done?
In the panel:
GNX-375 (GPS/Xpdr)
GNC-255 (Comm/Nav/Intercom)
G3X touch screen (prob 10", maybe 7"), for engine/charts/EFIS
G5
Autopilot panel (maybe skip haven't decided)
The usual switches
Remote:
GEA-24 (instrument sub-panel)
GAD-27 (??? under the seats)
GSU-25 (??? under the seats, next to battery?, still have to run tubing to G5)
GMU-11 (probably on the right wing tip)
GAD-29 (why do we need this these days for one GPS input)
If wanted: second remote radio and audio panel (??? under the seats)
B&C backup alternator controller (instrument sub-panel)
Considerations:
Only one radio, and use headset bluetooth for radio/phone/etc
Maybe skip autopilot panel as no yaw director needed
Keeps number of remote items low
If second radio will get GTR-20 but then need audio panel
Hi,
I`ve mounted the GAD-27, GEA-24, GSU-25 and my traffic device (europe) on a shelf behind the panel.
In the panel I have a GDU-460, GNC-255, GMA-245, GMC307 and a G5, further I have a smaller version of the Vans map box installed.
For the rear seat I have a GDU-450 and where normally the battery goes I have a GTX-23ES Transponder. Further I have a GMU-22 in the tailcone and a GMU-11 in the right wingtip.
See the attached pictures (pictures were taken during building phase.. all normal nuts were replaced by locknuts or nutplates..)
I tried as best as I could to separate the signal wires from power wires as you may see in the first picture. Towards the firewall are the signal wires and towards the panel the power wires.
As you can see in the last Picture, I have left some space above the autopilot panel to install a GPS175 in the future (I would move the autopliot panel up and then the master caution and warning lights away)..
ID:	8134  Click image for larger version
ID:	8135  Click image for larger version
ID:	8136  Click image for larger version
ID:	8137  Click image for larger version
Yves - Basel, Switzerland
RV-8 #83458 HB-YUA
Donation 2020 done
Old 02-09-2021, 02:12 PM
TASEsq TASEsq is offline
That’s a beautifully neat install!
What’s the purpose of the diodes on the keep alive terminal block?
Did you 3d print those static line clips? (They are a great idea). Can you share some photos of them?
What is the speaker for?
___________
Trent Stewart
Melbourne, Australia
http://www.tasrv14.blogspot.com.au/
Aug 2021
Old 02-09-2021, 06:29 PM
Hi Trent,
thank you.
The diodes are used for the second power-in for the GDU-460, GEA-24 and GSU-25. I have either the keepalive power or the backup battery and to not discharge one or the other they are blocked over the 25A schottky diode.
I used 3D printing in several spots.. the one mentioned is only a „figure 8“ to connect the pitot and static line.. I also printed some for 3lines (3rd is AoA) with a slot for a #8 nut included.. so on top of my shelf are the pitot lines and below some power lines.. I also printed a bracket to make a strain relief for the cables from the CB‘s as well as some brackets to mount the CO Monitor..
The speaker is to listen to the ATIS before I wear the headset.. But I rarely use it and would not install it again..
Have a great day down there
ID:	8171  Click image for larger version
ID:	8172  Click image for larger version
ID:	8173  Click image for larger version
RV-8 #83458 HB-YUA
Donation 2020 done
Old 02-13-2021, 03:17 PM
Hi Yves,
Makes sense re the diode - thank you.
Those are great ideas re the printing, especially the CB strain relief clips. Nice!
___________
Trent Stewart
Aug 2021
