Old 06-23-2021, 08:23 AM
pa38112 pa38112 is offline
Default P-mag rubber hose
I am thinking the rubber vacuum hose that comes with P-mags should be replaced every three years. Does anyone have a source for this hose, or an alternative?
http://aprs.fi/N153MC
2004 RV6A Flying
2002 RV6A Flying
1978 PA38-112
Old 06-23-2021, 08:28 AM
dothetime dothetime is offline
Default Hose
I used a silicone
hose
Probably last forever
Old 06-23-2021, 01:45 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Just a field report - the original ones in our RV-3 (flying ten years) look and feel new….
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 06-23-2021, 08:03 PM
The ones I got from Pmag were silicone. I think they should last quite a while. Much longer than rubber.
SH
RV6/2001 built/sold 2005
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
RV6/Used kit purchased 2021 building
Cincinnati, OH/KHAO
JAN2021
Old 06-24-2021, 06:47 AM
Paul
Paul, thanks for the report - I'll go a few more years before worrying about it.
I assume in 10 years you have had your P-mags upgraded at least once, but any longevity/preventative maintenance issues? I have had mine three years. I check the input shaft for play each year. - Anything else???
2004 RV6A Flying
2002 RV6A Flying
1978 PA38-112
Old 06-24-2021, 08:26 AM
Ironflight's Avatar
Well we’ve got four airplanes with dual P-Mags now, so it is a little hard to remember who has had what done. But the plane with the most years on P-Mags is actually the RV-8, probably 12 years? They’ve been back twice for upgrades….actually, one went back for the only P-Mag failure I have had, the old “shaft clearance” thing, and that got fixed. then they both went back for a software upgrade once. The RV-3’s have gone back for one software upgrade in their ten years if I recall correctly. The Tundra and RV-6 units are new enough that they are up to date.
To be honest, the P-Mags are far less maintenance intensive than the Slicks they replaced - they pretty much just work, and we maintain them as required.
Paul F. Dye
Old 07-19-2021, 07:55 AM
Finger Lakes RVer's Avatar
Finger Lakes RVer Finger Lakes RVer is offline
Default Hose ID?
Ordered the P-mags to get into the 21st century. Does anyone have the ID of the hose provided? I'm looking to get the supplies (T-fitting in this case) in advance of the installation.
John "JB" Balbierer
Ogden, UT
1998 RV-6, N30JB
Old 07-19-2021, 09:30 AM
Call TS Flight Lines. They sell a really nice kit for this...
2004 RV6A Flying
2002 RV6A Flying
1978 PA38-112
Old 07-19-2021, 04:23 PM
The black silicone hose from Brad is .125 ID. Same as the -3 hoses we use.
Tom
RV7A Tail Kit Completed, Fuse started-Pay as I go Plan, on hold while we develop new products for RV builders
Ridgeland, SC
