Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 05-05-2022, 09:00 AM
DHoover DHoover is offline
Default Prop Swap: Catto to Hartzell - What test data do you want?
As the title says I'm swapping from a 3B Catto to a Hartzell in my RV-7. Thanks @Walt!
I'm waiting on my prop gov and cables to show up for the swap so I've got a little time yet and wondered if there's any specific test data folks would be interested in for this particular permutation of propellers?
Here's what I've considered so far:
- Measured change to CG (I'm too tail heavy currently)
- Takeoff performance
- Cruise performance by fuel flow, % Power, MP and RPM (I'd like to be able to judge blade efficiency knowing the Catto is really good)
- Measured Sound Level (my wife is an audiologist and I promised her it'd be quieter in cruise - hope I'm right)
I'll take any advice on testing these but what else would help folks choose props?
Darin "Dyson" Hoover
San Antonio, TX
N24726 RV-7 Flying
Old 05-05-2022, 09:07 AM
PilotjohnS PilotjohnS is offline
Default Looks
Which prop looks better. after all one only sees the plane and the prop when things are stationary on the ground.
(I am joking of course, sort of)
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2022, worth every penny
RV9A- Status:
98% done, 2% left to go
Structure done (less gear)
Electrical/Panel done
Firewall Forward 95% done
Fiberglass 90%
www.pilotjohnsrv9.blogspot.com
Old 05-05-2022, 09:20 AM
grjtucson's Avatar
grjtucson grjtucson is online now
Default Good (or Bad) Vibrations
Suspect measuring this would be difficult/involved/expensive but I'd certainly be interested in your subjective comparison of vibration levels / "smoothness".
George
George Jenson - http://www.georgejenson.com
Tucson, AZ - N567AJ RV-7 Standard Build
Empennage 1/06, Wings 11/06, Fuselage 9/08, Panel Wiring 7/19, to airport 10/20, first engine run 2/21. AWC 11/11/21. First flights 11/17/21. My first flight 12/17/21, my first solo 12/20/21.
Monthly donor, I appear on the list as Jenson Consulting
Old 05-05-2022, 09:55 AM
Mikeyb Mikeyb is offline
Good Test!
There doesn’t seem to be a lot of quantitative data on the effect of engine braking. For instance the flight profile from cruise to pattern speed with both props.
More of a stunt than a measurement but I’d love to see the time required to do a circuit of the pattern at your airport takeoff to landing with both props.
Mike
Mike
N36MB
SN 83764
IO360-M1B
Hartzell Composite CS
Flying Phase 1
KAJO
Old 05-05-2022, 10:31 AM
John,
Hard to argue - the Catto wins the looks, hands down!
George,
Great idea, I'll think about a way to measure but certainly will provide the subjective assessment.
Mike,
I was considering using some kind of breaking test on approaches. Maybe 3nm final, 3 deg glide slope entered at a specific speed (120kts). I know the catto struggles to slow me to flap speed in with those parameters so maybe recording the speed at 1nm final would give the data we're looking for. I'll keep scratching my head on this one.
San Antonio, TX
N24726 RV-7 Flying
Old 05-05-2022, 10:53 AM
Steve Watkins Steve Watkins is offline
Default Stabilized descent rate?
How about descent rate at idle power @ 80 or 100kts? Flaps up, fine pitch vs Fixed Catto. What are the specs on the engine, the Catto and the Hartzell? I have a catto 3 blade 68x76 on my 180 hp M1B powered RV-8 and have been debating switching to CS for a while. I'm interested in your findings. Thanks!
Old 06-07-2022, 04:43 PM
Default Update
Any update on your prop swap?
