Ross7A-builder
Member
What have other builders done for additional flooring, other than the outer skin and stiffeners, under the rudder pedals? Looks like it could use something to avoid outer skin dents and possibly add insulation.
I used aluminum honeycomb flooring.. same as airliners use.[/QUOThetrE]
Where did you find it?
It's a secret I had a contact at a huge private jet manufacturer in Savannah that got me a couple of scrap pieces
Funny guy!
I found it, but I can't say where!
Classic Aero makes a carpet set that fits beautifully. They also provide a closed cell foam that fits in between the floor stiffeners. The carpet and foam reduced the noise and vibration level by a significant amount on our RV-7A.
https://www.classicaero.com/web/pub...97&ProductCategory=RV-7A&ProductCategoryID=13
Their entire interior package is amazing and still looks like new almost 5 years later.
Here you go Larry. I like the fact that it doesn't have padding or glue to off gas during a fire event.
https://www.mcmaster.com/aluminum-honeycomb-panels/
