Keep VAF
Going
VAF on Twitter:
@VansAirForceNet
04-22-2022, 06:55 AM
i think ''mogas'' is what is in the tank in the ground. it is 91 octane no lead for $3.99/gal at my airport now.
Bob Noffs
n. wi.
dakota hawk/jab 3300 built and flying. sold 6/18.getting serious about the 12. in the hangar now as of 10/15/19
RV-12 kit as of 9/13
RV-12 airworthiness cert. 11/30/2021
first flight 7/25/2022
04-26-2022, 09:33 PM
Has anyone reached out to the factory to see what modifications would need to be done to accommodate the different engine?
Chris C.
Private Pilot
RV-9A Emp Ordered - Feb '22/ Rcv'd May '22
06-01-2022, 08:50 PM
Originally Posted by hpmicrowave
In a discussion with a reliable source at the end of Sun n Fun this past weekend I was told about an ongoing flight test program with a RV9 and a Rotax915is. The source said the upgraded RV9 can easily keep up with the RV fleet at 9k and above. The conversion package his company is working on will be complete with prop, cowling, and firewall forward and will be brought out soon when all the testing and details are complete.
On the other hand this might just be a Rotax POC working with Vans Aircraft developing the firewall forward design details for the RV15??
From my experience with the 915is I believe it's one, if not the most sophiscated reciprocating aircraft engine available today. It's fully computerized with redundant computer, fuel and ignition systems, turbo charged and inter cooled, gets full power to around 15k, computer will always work to get the most efficient fuel power combination with the single power lever. Burns mogas including ethanol mogas as well as avgas. And uses oil like a modern car engine does. Oil changes every 100 hours using unleaded fuel and 50 hours with leaded avgas. It's not cheap but it's operating costs will make it a good option for many folks.
Your source sounds very reliable indeed. Here's a flight out of Sebring with one of the Vans company RV-9s (N179RV) that is registered with a Rotax 915. There were a handful of flights the end of April. This particular flight went up to an altitude of 17k where it looks like the ground speed topped out at 190 kts!
06-01-2022, 10:02 PM
Did you notice the 1,200-1,400fpm climb from 14k to 17k? WOW!
I hope they build a new cross-country airplane around that engine- the RV16 will be a great second plane for me to build.
RV12is #121441
Wing Kit received 7/11/22
Currently flying C-172M, 180hp Airplains
Dues paid 12/21
06-02-2022, 03:08 AM
That RV-9 might even be flying with the 161hp Rotax 916iS. Sebring would be a good place for development flying given Lockwood Aviation’s activities there
I heard the guys at Sling mention that the 916iS will be with GA consumers in the next 12 or so months. See this video from 44mins 40 onwards. https://youtu.be/lcFg7J5lIWw
Ed.
RV-3B G-LILB - Ex-N159SJ UK import Sept 2022
RV-3B G-CCTG - Purchased May 2020
RV-8 G-MIRV - Finished July 2019 - sold
RV-6 G-BZRV - Finished July 2002 - sold
06-09-2022, 05:39 PM
If I were building a -9 now, I would install a 915 without hesitation. Slightly less HP down low, significantly more HP up high - and that's where the -9 shines in comparison to her short-winged brethren.
The ability to (mroe easily) run Mogas is a big plus, too. Yes, I know a lot of VAFer's run Mogas now - myself included - however, I've had several vapour lock issues depending on blend, the 915, or EFI on a Lycoming, would avoid those issues.
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
06-13-2022, 05:24 PM
If Lockwood releases a FWF kit for this, I may just have a nice mid-time IO360 for sale.
That engine fits my mission profile perfectly.
Garden City, TX VAF 2023 dues paid
N16GN flying 1,200 hrs and counting on 91E10; IO360, SDS, WWRV200, Dynon HDX, IFD440, G5
Repeat Offender - 10 empennage in process.
11-25-2022, 11:10 AM
Still testing
I am really hopeful that the RV16 will be a xc machine with the Rv9 wing and a Rv14'ish cockpit. Looks like this thing is turning ~170ktas at altitude with 1,400 fpm climb all the way up. I'm sure all hand on deck to the RV15 launch, but pretty cool to see continued testing on this plane.
https://flightaware.com/live/flight/.../KSEF/tracklog
Happy Thanksgiving everyone.
RV12is #121441
Dues paid 12/21
11-26-2022, 01:02 PM
Originally Posted by mags591
That is awesome. I was not aware of this. I will have to do some more research. I am a newbie when in the aviation world.
Do you need any sort of aftermarket modifications to do this or is the engine capable of burning Mogas from the factory? What is your performance like with the mogas vs. 100LL in the O-320?
The biggest threat in your area will be vapor lock on a warm spring day. You may encounter winter-blend gas which vaporizes easier at lower temperatures. This may be mitigated several ways, but the easiest is to run on tank with 100LL (or 50/50) and takeoff and land on that tank.
Tim Holmes
Appleton, WI
RV-9A N904DC
2023 Dues Paid
11-26-2022, 01:44 PM
Testing has shown that as little as 10% 100LL in a tank of mogas can significantly drop the vapor pressure and (help) prevent vapor lock. You get most of the benefit of reduced vapor pressure by the 25% mixture point.
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
