Keep VAF
Going
VAF on Twitter:
@VansAirForceNet
11-25-2015, 11:08 PM
stumbling onward. disaster... the day after the wheel pants dried and still in the booth I thought I should bake them so I turn the electric heaters on. after about an hour the pant next to the heater began to exhibit what I researched was solvent popping. turned the heaters off.
booth 80F
my painting method was primer, wait 30 minutes, then one medium coat Concept, wait 10 minutes, then second coat Concept. it was raining outside and 50F. this is the pant with solvent popping on one side that was next to the heaters.
this is another couple of pants that look OK, not next to the heat. But not as smooth as when first painted.
perhaps I didn't wait long enough between coats. I will try a some coupons to test before painting any more Concept. do not bake these parts 24 hrs after painting.
I removed the spray can self etching primer off the tips of the control surfaces with lacquer thinner because when I primed the overall I left one area at the tail, behind the rudder, in self-etching primer and it lifted. self-etching primer under this surface.
self etching primer washed off and new DPLF and K36 primer applied to tips. I also sanded the trailing edge of the elevator tips to a better looking edge. they were originally very thick.
First time to try DeKups for painting upside down. It works and I like it. note: the overall aircraft was primed with a loaned citation turbine sprayer that was nice but needed to be reconfigured for spraying upside down and had some drip problems. it was a bottom feed cup and holds a lot of paint so that was good. the DeKups reservoir is not as large.
James Bond light helmet. Even with the lighting the end is not in sight.
11-28-2015, 08:52 PM
11-28-2015, 08:56 PM
a good tip, mark the plastic measuring container
taped a sweat drip guard to the low point of the facemask
here's what happened, a sweat drop, the risk you take painting horizontal. I soaked the drop off with a small paper towel and recoated with primer and continued on. something to remind me of my painting adventures.
my alodine is not perfect cover, is it ever? no alumiprep, just dawn and scotch-brite pad. maybe that's why my alodine is not better.
11-29-2015, 07:06 AM
I use Alumniprep and I see no difference in the appearance.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
11-29-2015, 09:14 AM
Alodine process
Steve
How did you Alodine large surfaces? Brush? Spray?
How did you catch the runoff?
How did you rinse?
Larry Larson
Estes Park, CO
E-mail: wirejock at yahoo dot com
Builder Blog: http://wirejockrv7a.blogspot.com
Donated 12/2022, plus a little extra.
RV-7A #73391, N511RV reserved
Disclaimer
11-29-2015, 05:37 PM
how do you pour paint from a full can and not make a mess? use a homemade plastic funnel and punch 4 holes in the can to let the paint back in. a good tip from Bill Duffy. save the paint, it's expensive.
I gained another ounce by letting it drain completely
flap and aileron
primer, wait one hr then paint, the primer always looks good. I always thin it per the manual with acetone. flows really well and hides scratches. amazing stuff.
paint, 5C outside, DT870, preheat part to 80F, two coats with a little more on the top side, which is the downside in the booth. wait 15 minutes between coats to let the solvent escape. time between coats is the key. to much time and you need a lot of paint, to little time and the solvents don't have time to flash. booth was 75F when beginning the second coat and cooled to 70F by the end of the second coat. I gave the lower side of the flap a half dust coat at the end to see if I could flow it out. it was hanging more vertical than the aileron. it didn't seem to help much and left a satin finish. so my conclusion is that you don't want to do this. put it on wet. hopefully the satin finish will flow out somewhat overnight.
the candles are lit, time to paint!
satin finish, hopefully this will flow out. vertical surfaces are more difficult to flow out. need to time it just right and put it on wet. I will try to get a picture of this tomorrow to see if there is any improvement.
parts "baking" overnight at 65F
11-29-2015, 05:54 PM
11-29-2015, 08:24 PM
Originally Posted by wirejock
Steve
How did you rinse?
spray, rinse with water, you need to be quick to catch it or it will runoff...
11-29-2015, 08:47 PM
Steve,
A couple things:
1. I found the best way to avoid solvent pop is to make sure the previous coat is "glove slick". i.e., spray a piece of cardboard near the end of your session. When you can slide your fingers over the test panel without sticking, you are good to go on the next coat. (the tech sheet probably refers to this)
2. The largest pump that comes in the West system pump kit screws right on a gallon solvent can and you can pump out solvent into your gun or cup or whatever. The pump is fine in the solvent. I've had one on my lacquer thinner can for years.
Good luck, it's a learning experience!
Mike W
Venice, FL
N164WM RV-6A Slider/O-360/FP Sold 4/2022
N184WM (RV-8) Flying. Titan IOX-370/ CS/G3X
N184P reserved (RV-8QB) Empennage kit and QB wings in the shop
11-29-2015, 09:16 PM
Originally Posted by fl-mike
Steve,
A couple things:
good tips, I think I have one of those unused pumps laying around. I'll put it to use. I'll try the cardboard. Question, does solvent escape faster/better with booth fans on or off?
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
