I am installing a G5 as a stand alone standby instrument. Eventually, I will have a magnetometer attached via the CAN buss but at the moment I have just attached power and fired it up.
I get the following indications:
- message saying "Hardware Fault"
- red X through the airspeed and "Airspeed Error"
- "Aligning" on the PFD which doesn't go away
I've looked through the install manual and can't find anything I should be configuring. Have I got an irrecoverable hardware problem or is there some way to fix this?
