Old 08-10-2022, 08:48 AM
edclee's Avatar
edclee edclee is offline
Default D-Day Stripes
I want to put D-Day stripes on my polished RV-9A wings and figure to use 8" stripes. I am trying to decide how gloss vs Satin or Matte would look and hold up. I am going to use Vinyl, not paint. Has anyone does this with Vinyl and what did you use?
Ed
Sonex/Corvair 2016 Finished, Sold 2020
RV-9A 2005 Purchased
IO-320 160 hp
Exempt but happily paid for 2022
Old 08-10-2022, 09:21 AM
abwaldal@gmail.com abwaldal@gmail.com is offline
Default Invasion stripes
I put invasion stripes on my white RV-6A and they are 8" wide vinyl in a sort of matte finish. Two each wing. Checkers on the flaps top and bottom.
I did not do the fuselage.
I bought a 50' roll for a pretty fair price from I actually do not know where. I might have that info at the hangar.
Have enough to do them again if needed.
Been on there for 2 years and not coming off.
I will say that the tank screws will pull it pretty badly. So I used flush style trim washers under the screw heads. Not Tinnermans.
Your luck may vary Art
Fixit
Old 08-10-2022, 09:31 AM
edclee's Avatar
Default Pic?
Thanks Art...do you have a picture perhaps? You did the top and bottom surface of the wing I presume?
Ed
IO-320 160 hp
Old 08-10-2022, 12:51 PM
I have a couple during some work that will give you the idea. Yes the stripes go top and bottom back to the flaps. They are 8" wide and 8" apart I believe. Not at hangar so guessing from memory.Click image for larger version
Art
Fixit
Old 08-10-2022, 03:43 PM
Bandera Bandera is offline
Ed
I usually do my invasion stripes 7 inches. I also only want them on the flaps.
Old 08-10-2022, 04:14 PM
riseric's Avatar
riseric riseric is offline
I used a 45 inch wide vinyl strip. It was custom printed.
Each white/black stripe is 9 inches wide.
That total width was to include the flap up to the wing walkway.
It's one piece top and bottom, the flaps are also wrapped with one piece all around.
ID:	29349  Click image for larger version
Eric,
2022 =VAF= paid
RV-8 SB #83274
Grove Airfoiled Gear, Wheels & Brakes
VPX-Pro, EFII System 32, EarthX batteries
Aerosport IO-375, MTV-9-B/183
Skyview HDX
C-GEMQ, RV-8, "Dragonfly", flying
C-GNFJ, C72R Cutlass, flying
Old 08-10-2022, 07:52 PM
jeffreyuh60's Avatar
jeffreyuh60 jeffreyuh60 is offline
Peeps,
I borrowed a buddy’s 9” wide invasion stripes to see how the looked on my RV-14. The RV-14 wing is just under 12’ long. Given the “rule of thirds” they seem too wide overall (9x5= 45”). Ideally, 36” (5 stripes at 6” wide each) seems apropos, as well as having the stars and bars at 36”, instead of the suggested 55.6”. Historically, smaller aircraft sported 9” wide stripes by technical order, but I feel this was more a function of the width of a standard paint roller, than any visual recognition calculation.
Thoughts?
Jeffrey Turner
RV-14 almost, almost finished
Jeffrey Turner
RV-14 N39JT, Lycoming IO-390 EXP-119 Thunderbolt
Passed airworthiness inspection. Entering phase 1
She built the hangar, I built the airplane. Best wife ever!
Second aluminum beauty is a 2017 30' Airstream Classic
