RE: RV-7 with OP-07 plans built system installed.
First 300 hours, tank gages worked well! Then I started seeing intermittent quantity indication on the right tank gage. Ie., it would show 'E-open' occasionally. Now it displays 'E-open' all the time.
I found the center conductor of the coax cable that is mounted on the inboard end of the fuel tank to be grounded. So somewhere inside the tank the plates, wire, or mounting screws have shorted to aircraft structure ground.
The best option would be to add a float sender to the end cap. My question is:
can this be done without removing the wing? Is there enough room between the fuselage and tank to install the float assembly?
I spoke with Van's today, and was told the capacitive system is no longer supported or offered. If anyone has run into this situation and knows a better solution, please advise. Thanks!
