Old 01-26-2021, 03:41 PM
philip_g philip_g is offline
Default airport refusing to rent me a hangar to build
to rent a hangar here they want the N-number, liability insurance, and most recent annual inspection. I can probably sort out 1 and 2, but #3 might be an issue.
I'm certain this is an airport that has received federal grant money and is bound by the grant agreements, to include what the FAA has designated as aviation use, which specifically includes building an aircraft.
however, they're saying no and I have no idea how or who to argue my point with.
from the airport handbook FAQ
Question 8. What aeronautical uses of a hangar are permissible?
FAA Response.
Storage of active aircraft.
Shelter for maintenance, repair, or refurbishment of aircraft, but not the indefinite storage of non-operational aircraft.
Construction of amateur-built or kit-built aircraft provided that activities are conducted safely;
Old 01-26-2021, 03:48 PM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
I would go straight for getting a letter from an aviation attorney.
You might be able to get through this yourself, but maybe not.
And, while they are stalling you with denials, they rent to someone else.
Alternate might be to enlist a partner who has a plane already, and get it that way?
Are you with AOPA?? They may be able to help.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 01-26-2021, 04:02 PM
I tried that but they already have the max # of hangars they will give them. Attorney letter might work, I'm trying to play nice in the meantime. I wasn't sure if EAA had any resources for me or if the airport even can deny me a hangar for an authorized use.
Old 01-26-2021, 04:06 PM
AOPA is probably a good resource too.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 01-26-2021, 04:16 PM
I dropped aopa somewhere along the line but if I need a lawyer I'll sign up and use their service. The guy I've used in the past is in a different state
Old 01-26-2021, 04:53 PM
terrykohler terrykohler is offline
Default Personally, I donít Respond Well to Threats
If itís an airport with a (long) wait list, your chances might be slim. Theyíve likely had experiences with builders whoíve never finished or used the hangar as a storage locker. In the meantime, itís one less opportunity to sell fuel or other services that the airport might offer. Youíre a drag on their business until/unless you finish. It might work better if you ask them for a possible solution rather then come in with guns blazing. Your problem is not uncommon. Try to think of it from their perspective and you may have a better chance of both winning.
Terry, CFI
RV9A N323TP
Old 01-26-2021, 04:54 PM
Originally Posted by terrykohler View Post
If it’s an airport with a (long) wait list, your chances might be slim. They’ve likely had experiences with builders who’ve never finished or used the hangar as a storage locker. In the meantime, it’s one less opportunity to sell fuel or other services that the airport might offer. You’re a drag on their business until/unless you finish. It might work better if you ask them for a possible solution rather then come in with guns blazing. Your problem is not uncommon. Try to think of it from their perspective and you may have a better chance of both winning.
Terry, CFI
RV9A N323TP
apparently there are available hangars. I thought there was a list but they just evicted a bunch of people. they can evict you for any reason they want (and often do)
if I needed to I could find somewhere to build and just take it to the hangar for final assembly. I just don't know where.
Old 01-26-2021, 05:04 PM
9GT's Avatar
9GT 9GT is offline
IIRC, this subject was discussed in great length here on the forum many years ago. The poor guy trying to get a hanger to build in, like you, ended up spending a small fortune trying to force the airport into renting him a hanger. It involved the municipality that owned the airport, many lawyer hours billed, his local and state reps, a lawsuit that he lost, and it cost him at least $20,000 to fight his loosing battle. Guns blazing and threats are not the way to go here. Good luck though. I would look for some local shop space to lease instead, either commercial, or private from someone with a pole barn you can lease. You'll end up with an airplane for that hanger you will want and need.
David C.
Howell, MI
"Donor Exempt" but donated through Dec. 2021
Old 01-26-2021, 05:15 PM
JET14 JET14 is offline
Default Airplanes with no home...
Hanger space is at a premium. I am on the waiting list at 3 airports but many of the hangers are filled with business inventory, RVs and airplanes that haven't been airworthy in a decade. Many have found they can enjoy the additional security that an airport can provide and use the facilities for everything except aviation. Not sure what their beef would be with you wanting to build an airplane. It's a quagmire without a solution as far as I can tell.
Old 01-26-2021, 05:16 PM
I've been keeping an eye out as it could be closer to my house but no luck, not for less than $1500 a month, anyway
