Old 01-07-2010, 01:33 PM
Doug Lewis's Avatar
Doug Lewis Doug Lewis is offline
Default Tall guys in 8s?
I've been itching to start on an -8 project but the only thing stopping me is the question of if I'll fit. I'm 6'6" with 38" inseam. Today someone was kind enough to let me try their 8A on and everything was fine except the leg room. Unfortunately he had the old style not easily adjusted pedals and they were set one notch behind the furthest forward position. I could get my feet into position, but my knees were bent out against the sides of the plane. The "tall guys" option appears to just recline the seat slightly rather than give any more leg room. Any other mutants out there that could give feedback?
Old 01-07-2010, 03:33 PM
skyking902001's Avatar
skyking902001 skyking902001 is online now
Default Tall pilots
Doug, I went thru the same delima trying to decide about the tall pilot option--although, I am not as tall as you are. Here is a link that helped me--hopes it helps you.
http://www.vansairforce.com/communit...als#post189462
Sky
8/8A?
Tail Started
Old 01-07-2010, 05:30 PM
Doug Lewis's Avatar
Sky, Thanks much for the link! It's good to hear from others who've actually sat in the plane. Can I ask what route youre taking?
Doug
Old 01-07-2010, 05:44 PM
chaskuss chaskuss is offline
Default Move the seat back
Doug,
Been there, done that. Definitely get the "tall pilot" option. You also can move the back of the seat rearward about 1.5". See my post with photos in the link below. It's the 4th post from the top.
http://www.vansairforce.com/communit...ight=seat+back
Charlie Kuss
Old 01-07-2010, 07:32 PM
Doug, first time I sat in the 8, had same issue as you, but I was wearing a heavy coat. Second time I tried it on, I was wearing a light jacket and had no issues. The 8 I was in had the in-flight adjustable pedals, set all the way forward. At this point, I don't think I will go with the tall pilot option, and instead try to handle the issue by thickness of seat back padding. If you have the opportunity, might "try on" a couple of other 8's. I hope to check out at least one more before I place my order for the fuse (probably 3 to 4 months away). Best of luck in your search.
Sky
Old 01-08-2010, 06:09 AM
Doug Lewis's Avatar
Thanks Charlie, that certainly looks doable and the pictures are a big help as well. Scott at Vans sent measurements from the seat pan to the pedals pushed all the way forward to compare it to the one I sat in to see how much room thats available.
Doug
Old 01-08-2010, 09:26 PM
Stretch Stretch is offline
Doug
I am 6'7" & 250. I am in the process building a QB 8 and share your concerns. The main reason I went for the 8 is because Vans told they 6'10' pilots flying them. I suspect there have been some poetic licence in quoting the measurements..... anyway....
I have the tall pilot seat brace option and have moved the seat hinge rearwards by about 1.2". Only problem is the seat belt mounts which now touch the seat back.... they are already installed on my QB. I think I can shorten them by about 1/2" without having to drill out and re-make and may have to modify the holes in the seatback through which the seatbelt passes. With the adjustable rudder pedals full forward I think I will have enough room - but may have to step outside to change my mind.....
I had my first sit in the partially completed cockpit yesterday on a couple of pillows and it seemed ok.
Regards,
Don Muir
Don
RV8 QB - started June '09
First Flight - Apr 2018
Previous C172 Penn Yan 180hp (Sold)
Old 01-09-2010, 06:55 AM
N208ET N208ET is offline
Default One thing that helped me
I got the ground adjustable rudder pedals, they allow my feet to slide under the rudder pedals and rest on the firewall. This is a very comfortable position for me and I am 6'6" with a 36 inseam. The 8 is big enough that you can make it fit, might have to give up some padding in the seat cushion and seat back but it will work.
Randy
Old 02-28-2010, 06:05 PM
Doug Lewis's Avatar
Just a follow up. My wife and I took a drive to Portland, ND this weekend where one of the forum members here offered his tall modified 8 as a test fit. What a difference! No real issues at all with about 4" of foam under me. His seat hinge had been moved back as far as it could while maintaining stock stick clearance in the back seat, and the tall option used at the top. The only thing I may do in addition is add some small knee wide cutouts in the bottom of the dash. Knees didn't hit, but I could see it'd be close if we put much foam behind. Headrooms not an issue at all.
Thank you Lance and Bob for letting me play in your 8's. Once again everyone we've met in this community has been wonderful. Started the practice kit today. Tail kit should be ordered tomorrow.
RV-8 Wings almost done
QB Fuse waiting
Show Planes Fastback ordered
N238L Reserved
Old 02-28-2010, 08:04 PM
lancef53 lancef53 is offline
Glad to see you made it back home, have fun getting started
Lance
RV-8 108LF
