Old 04-11-2021, 08:22 PM
JDA_BTR JDA_BTR is offline
Default Bushing for manual aileron trim
I'm putting together the manual aileron trim, and there is a .437 snap bushing with a nominal 1/4 diameter that needs to be opened out to 5/16. Vans says use a Dremel; the snap bushing scoffs at the bits available to me. The snap bushing responded to the drill bit as predicted by Vans - destroyed....
Who knows the Dremel attachment to eat that hard plastic? Or is there a better alternative. I suppose I could fashion a Delrin block to take a 5/16 hole and screw it on there....
Ser 140142, RV-14A flying - N1463
Ser 83825, RV-8 building - N8638?
USN Ret, Urologist, AME, Repeat Offender
Old 04-11-2021, 09:02 PM
skyking902001's Avatar
skyking902001 skyking902001 is offline
Default Dremel with stone
Did this so long ago, had to refer to my Kitlog to see how I did it. I used a pointed stone in the Dremel and carefully opened up the snap bushing to the required size. Didn't seem like a big deal at the time and the manual trim still works after 170+ hours. YMMV.
Steve Riffe
RV-8
N23SR
Dues paid to 12-1-21
www.mykitlog.com/skyking90200
