Spark plug resistance
g zero
Having started another thread about my spark plug dilemma, I'm curious about the 5000 ohm cut off point . Auto plugs recommend 5000 ohm resistance to reduce radio interference ,yet Tempest wants us to trash a aviation plug with the same resistance .
With a magneto sending 20,000 volts (?) to a spark plug how much resistance is too much ?
I had my transponder cert done yesterday at a local shop. While I was there I had a nice talk with the mechanic about this. To boil it down, he said that they see MANY Champion plugs over the limit during bomb tests but if they are not causing a problem, or the owner hasn't asked about it specifically, they put them back in service. He also said that they buy Tempest exclusively now. I am paraphrasing from memory but I think I got it pretty close to what he told me.
G_Zero, I have spent some time trying to figure out what is going on with the resistor. Here is the best I can offer for now, others may wish to elaborate or correct.
A magneto has a primary circuit that consists of a parallel LC oscillator, that is an inductor and a capacitor connected together one side connected to ground. The magneto points short the capacitor (and the inductor since it is in parallel) - current is induced into the inductor when the magnetic flux changes through the core of the coil - when the points open the LC circuit starts oscillating and continues to do so until the energy dissipates in the circuit.
The Inductor also has a secondary high voltage winding that connects via the series resistor to the spark gap. The reason for the resistor is to limit the current to the spark gap reducing the energy rate being bled from the oscillator circuit. Low resistance - very short high energy and less consistent spark, Optimum resistance - appropriate spark duration, lower average energy and consistent spark.
Note the spark is not one single strike but a high frequecy series of strikes at the rate at which the oscillator resonates, continuing until the voltage drops (due to the falling energy in the oscillator) below the threshold required to conduct across the spark gap.
The short duration high energy spark also causes more spark gap electrode erosion.
A high series resistance will result result in a slower discharge and longer duration but more dangerously the high voltage may find another site to discharge other than the plug gap. Since there is no limiting resistance for a secondary breakdown the spark will be high energy thus damaging.
In essance a too high a series resistance allows the HV to look elswhere for a path to ground.
So what determines the optimum resistance? This would be a function of many varibles - inductance, capicitance, LC circuit resistance, isolation gaps, insulation materials and dielectic constant, circuit resistance, spark gap and electrode design.
Incidentally I just realised that the 'p' lead of the magneto shorts the capacitor and inductor primary to ground - so 'p' is probably an abbreviation of 'primary'.
I use Tempest. but I understand from the Mike Bush Last news letter that
Champion is now going to the same resistor deal that Tempest uses.
Jack
It is amazing... so much bashing by Champion and their loyal mechanics.... now they are joining the group :)
Here's a p-lead waveform that shows ringing that provides the multiple spark events. This was taken from an IO-540 in flight.
This also illustrates how it is sometimes difficult to get stable rpm readings using the P-lead signal.
Plugs
I cleaned all the plugs , checked them all with an ohm meter . Ohm readings were all over the board ,bomb tested them and they all looked fine . Reinstalled them in the engine and mag tested fine .
Will report back after my next oil change or plug/ mag problem witch ever comes first .
This also illustrates how it is sometimes difficult to get stable rpm readings using the P-lead signa.
Vern,
That image is a gem. It also illustrates the decay in the energy during the sequence. Thanks for posting. Any chance you can put some parameters on the grid?
This right here gave me $25 worth of thinkin'. Thanks Doug, Vern and the original Doug of course.
I'm having trouble checking resistance on my spark plugs using an VOM (Extech MN-35 (China) through Amazon.) The meter works, but none of the plugs seem to have continuity between the center electrode and inside contact (at the base of the "neck" of the plug.) Do I need some super-powered VOM meter to do the test? Is there a trick to get proper contact inside the plug? I've tried bolts, and even bought some especially long-tip probes. To be clear, I'm checking for both continuity and resistance, but the VOM shows an "open" circuit, i.e. no connection. Puzzling.
Make sure the center electrode is clean and you are making good contact. If they are Champion plugs, don't bother, throw them away and just buy new.
I had a Tempest that measured as an open circuit. It turns out there was some crud inside the barrel where the spring makes contact. The tech support guy at Tempest told me he cleaned it with solvent and Scotchbrite and tested fine after that.
Jerry Esquenazi
RV-8 N84JE
Vern!
Thanks for the picture, I have a Flight Data Systems T-30 electronic tachometer which reads 'way too high at flight RPM for about 15 minutes of flight.
I bet that secondary voltage kick is coming back thru the P lead and filter resistor!
Tempest
Thanks to Tempest we have plugs (including the new Champions) that appear to be well manufactured. Before Tempest the ground electrode was haphazard, at best! Now, we have a quality-looking product, consistently built & with understandable tolerances. The impact on Champion regardless of their protestations has been to deliver a quality product that equals Tempest's product; that happens when market share erodes dramatically! And, for the prices charged, they should reflect a high quality, precision manufacturing process.
In the late eighties a new O200 jug was running $1400 (no piston). Continental swore up and down that it was impossible to sell at a lower price. Then Superior came out with cylinder kits at just over $600. Factory cylinders miraculously dropped to eight hundred and Continental didn't go bankrupt. Real funny how that works, isn't it?
Help!.....can't see 5000 ohms anywhere!!!!
first, I am electically challenged.(Thankfuly I spel gud!)
Took gr. 8 electricity for a few months.
I just tested all my box o' plugs with 2 different ohmmeters, planning to go swap in a fresh set after borescoping my engine.
brand new massives tested at 1.55 to 1.87 out of the box.
several scales on my Ukrainian Tire multi-meter tester gave this same 1.xxx result, so there's confusion #1. ( used 20K and 2k settings)
older fine wire showed .53, 1.2, 1.7 giga-ohms or whatever.
older massive showed from .77 to 1.128, average around 1.000
what the heck does all this mean? ( all autolite/unison of various vintage)
The primary circuit is always grounded when the points are closed, that is how it builds the charge. The P lead is bridged to the primary circuit via the capacitor (this is known as the condensor), allowing you to permanently ground it. Then, even when the points open, the circuit is still grounded and the magnetic field cannot collapse into the secondary circuit and release the energy into the plug circuit.
Larry
It has been my belief that low resistance is preferred for the plugs and this was also the standard in the auto industry until radios were introduced. By increasing the resistance of the plug, RFI is reduced (don't know the science behind why). The big difference is that an automotive coil puts out MUCH more energy than the mag' coil and can afford the loss caused by the resistance.
Your meter reading probably has a "K" at the end. That K stand for Kilo- and means X 1000. THerefore, 1.55 = 1,550 ohms and 1.87 = 1,870 ohms, etc. I bet now you are wishing you paid atention to that Metric stuff they were trying to teach you in school.
so these are all good???
thanks Larry, sounds like all these from 500 to 1500 ohms fall in the 'OK' range.
am REALLY curious why the new plugs would be so much higher than old, cooked, well vibrated ones?
any ideas??? is there anything I can look for, or do from a cleaning standpoint to get the lowest resistance?
thx
