  #71
Old 04-20-2017, 03:10 PM
turbo's Avatar
turbo turbo is offline
the slider piece finally broke after 18 years and many hours of use. and by blind luck i found a new piece in my rv drawer. have no idea where it came from easy fix for a non builder. i like these kind of issues.
i also found an easy way to get my slider off and on solo. i fabbed up this special board to help lay the slider on before attaching the rear and then the front.
TURBO YES =VAF= Payed Jan2022
Ed D'Arcy
RV6-A 5,400+ hrs, R-44 1,700 hrs, Helicycle traded for 33 FFR coupe, 300 young eagles flown
Stuart, Fl / East Hampton,Ct / Virgin Gorda, BVI - villa sold.
addicted pickle ball player
Old 04-20-2017, 06:37 PM
Good job Turbo! When northbound?
Old 04-21-2017, 09:29 AM
morganjp morganjp is offline
If your interior paint is badly worn then head on over to any auto parts store and pick up a few cans of trunk spray paint. It is textured and really looks great. I can't say how long it will hold up as I just did my 6-A with it. I would post pics but I am technically challenged. As it wears it will be very easy to touch up as the texture in the paint prevents The appearance of being painted over. If someone else has done this maybe they can post a pic.
John Morgan
Atlanta, GA KPDK
N613SC
RV6A -SMILIN 1
Old 07-18-2019, 03:07 PM
That's what happens to the shiny rod ends after 7 years of being under the elements
The aileron stops were once yellow and hard. Became white and brittle.
Now machined out of aluminum thanks John. Should last a century.
Old 11-22-2021, 06:39 AM
Default Center bottom skin wear
Those who are still building and expect a lot of flying take a look at this center bottom fuselage skin wear F-976. You might want to prevent it by putting a sort of anti chafing material.
