Old 01-23-2022, 05:30 PM
rvbuilder2002's Avatar
Originally Posted by Mel View Post
Even though I am an A&P, and have been for almost 50 years, I still have a different mechanic do my inspection every few years. Different eyes see different things.
I've been proposing to the FAA for several years that a "Repairman" for an amateur-built aircraft should be required to have an experienced mechanic walk him through his first Condition Inspection. Knowing how to build an airplane does not mean that you know how to inspect one.
Just my opinion! Obviously not a real popular one.
I agree with you Mel. But rather than the FAA getting involved and making a rule I would prefer that people just did that on their own. I promote it to any builder with a newly completed airplane.
Scott McDaniels
Hubbard, Oregon
Van's Aircraft Engineering Prototype Shop
FAA/DAR
Old 01-23-2022, 06:51 PM
RVDan RVDan is offline
Originally Posted by jrtens View Post
Yep - got that - see post #6
Not talking about who can do the maintenance anymore - talking about the requirement for maintenance records.
A statement was made that "no logbook or records are required to be kept at all for EAB except for the annual condition
inspection." My question was where does it say that FAR 91.417 doesn't apply to experimental aircraft?
Inquiring minds want to know.
It is important to note that this is a part 91 requirement not part 43 and therefore 43.1 does not relieve one from the 91.417 requirements. Unless there is something else exempting EAB from record keeping, I would agree that the owner/ operator has to keep these records.
Dan Morris
Frederick, MD
PA28-140 sold
Hph 304CZ sold
RV6 built and sold
N199EC RV6A flying
Retired Aerospace Engineer and A&P/IA
Old 01-24-2022, 06:01 AM
Walt's Avatar
Walt Walt is offline
I'll go one step further and say that the builder is actually the worst person to do the first condition inspection, they will assume things are good because that's the way they built it. Can't even remember how many sump screens I've pulled that still had the original Lyc safety wire installed after years of inspections.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags, MTV-9 prop
Old 01-24-2022, 06:34 AM
MacCool's Avatar
MacCool MacCool is offline
I always have my A&P review any significant work that I do on my airplane, but I donít ask him to sign off the logbookÖhe signs only if he actually does the work. I donít do any work forward of the firewall. I even have him do the oil changes because itís worth it to me. As to the annual inspectionÖI pull the interior and the flooring, luggage bulkhead, and inspection panels as a means of saving some money and learning about the airplane, although the time spent doing that is such that Iím on the fence as to whether or not itís worth it any more.
RV-9A, 2011, bought flying
IO-320D1A (factory new), C/S
IFR equipped
AFS 5400/3500, G5, IFD440 navigator,
bunch of other stuff
Old 01-24-2022, 06:53 AM
DanH's Avatar
DanH DanH is offline
Put me in the bin with Scott. I absolutely agree that quite a few builders do a poor first condition inspection...but no, we don't need a new rule mandating A&P involvement.
Let's not kid ourselves. I have seen some really dumb stuff in one year old airframes from very experienced builders. I had a lot of personal experience correcting outright dangerous things in an airframe signed off by a highly qualified DAR, and I'm pretty sure that DAR signed off the entire production series. And I once found a torque tube/aileron pushrod bolt with no nut, no indication it had ever had one...and I was the builder.
Point is, mandating some particular class of mechanic is no solution. Inspection isn't about qualifications. It's about actually looking closely, and almost anyone can fill that role.
Dan Horton
RV-8 SS
Barrett IO-390
Old 01-24-2022, 07:04 AM
mdevans9 mdevans9 is offline
Default RE: CFR 91.417 Records
There are definitely two camps regarding the applicability or not of CFR 91.417.
Likely will not change any minds, but here is an article that tries to sort through the inconsistencies.
https://www.kitplanes.com/aircraft-r...-and-logbooks/
Merrill
Merrill D. Evans
RV-7
N87EM
Old 01-24-2022, 08:09 AM
Ventus Ventus is offline
Default What Can I Do?
As a current & previous owner of several experimental aircraft, and a buyer looking for an RV-8, I like to see clear documentation of all maintenance and repairs performed. I prefer to see occasional IA or A&P entries in the logbooks showing that multiple sets of capable eyes have looked at the plane and found it airworthy and contributed to itís maintenance.
3C
N103CR
Pitts S1-C Sold
Pitts S1-T N49338 Sold
Staudacher S300 540MG Sold
Old 01-24-2022, 08:43 AM
My mistake.
I thought I clicked quote on a different persons post on page 1.
I agree that anything written in Part 91 applies to Experimental Amateur Built aircraft.
Including a lot of others that owner inspectors often miss. One of those that is often overlooked is FAR 91.207 (which within the part specifically mentions an entry in the aircraft maint. records is required.
Scott McDaniels
Hubbard, Oregon
FAA/DAR
Old 01-24-2022, 03:49 PM
Just to be a contrarian, I note that 91.409 (c)(1) specifically excludes EAB aircraft from a small subset of the rules. More generally, a lot of the 91.4xx rules reference Part 43 - which specifically excludes EAB. How are we to interpret these?
Old 01-24-2022, 10:00 PM
Even though I interface with the FAA on a pretty regular basis, I am still far from having any expertise at interpreting the FAR's, but I think this one is pretty self explanatory.
91.409(C) says "Paragraphs (a) and (b) of this section do not apply to..."
So it is saying that only 91.409 doesn't apply to an experimental. Just because one Section (section is the portion of the "Part" being identified with the numerals after the period) doesn't apply, doesn't mean that all of Part 91 doesn't apply, or that any Section in Part 91 related to inspections don't apply. Only that Section 409 doesn't apply. I believe this would be the case for any other section in Part 91 as well.
91 is the Part, 409 is the Section, A & B are the paragraphs within that Section.
Part 43 is different. Its exclusion statement says " This Part does not apply to -". That means Part 43, in its entirety, does not apply to an experimental.
Scott McDaniels
Hubbard, Oregon
FAA/DAR
