Keep VAF
Going
01-14-2022, 09:49 PM
Strange registration certificate - maybe a mistake?
Good news is that my registration certificate has been issued! One step closer to flying. The strange bit is that unlike every other RV registration I've seen, where the manufacturer is the builder's name, mine appears to list the manufacturer as VANS AIRCRAFT INC. This doesn't seem correct. I know I filled out the paperwork exactly as the EAA registration kit specifies, and have the copies to prove it.
Any DAR care to comment? Should I expect to encounter problems down the line when applying for airworthiness and/or repairman's certificate? If so, has anyone had any experience with requesting a correction to the FAA's registration database?
01-14-2022, 11:00 PM
Sounds like either a new employee or change in policy. You could call and question it or just accept it and make sure your Airworthiness Cert application and data plate match the registration.
Greg
1950 Navion - flying
RV-6 - first flight 5/6/2021
1940 Rearwin Cloudster project in progress
4 L-2 projects on deck
01-14-2022, 11:12 PM
Senior Curmudgeon
Have you already chosen a DAR for your inspection??
If so, check with them.
Or, you could call Dilly 916-606-4160 and see what he has to say.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
01-15-2022, 04:31 AM
Get it fixed!
Vans didn’t build that plane. You did!
I recently had a client who used one of the “walk your papers thru Okc”
They made the same error.
Call Aircraft Registration in Okc and get it fixed .All AWC entries are based on an accurate record.
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
01-15-2022, 04:51 AM
What do you mean by “appears to list the manufacturer. . . ”?
Maybe post an image of what you received.
Philip
Based Creve Coeur Airport (1H0)
RV-6A - flying 1000+ hours
Paid dues yearly since 2007
There is something fascinating about science. One gets such wholesale returns of conjecture out of such a trifling investment of fact. —MARK TWAIN
01-15-2022, 06:20 AM
Yes! Your registration is in error. As said before, call Oklahoma City and get it corrected. All certification information is based on the registration. It MUST be correct.
Mel Asberry, DAR since the last century. Over 1,000 certifications accomplished. Discount for Veterans, Law Enforcement, Fire Fighters.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
01-15-2022, 08:18 AM
Based on an online query only. They cashed my check so I went online to verify. Based on the replies here I’m going to wait to get the paper certificate in hand then decide what to do from there.
01-15-2022, 08:37 AM
Waiting on the paper certificate will only delay further. The paper certificate will match the online information.
01-15-2022, 08:43 AM
Registration
Out of curiosity, I just looked at my registration on FAA.gov.
It show my name as the manufacturer at the top of the page, and at the bottom of the page lists "kit manufacturer" as Van's...that would make sense.
Bob
Aerospace Engineer '88
RV-10-ER
N464RL
Going to Paint at Evoke!
Garmin G3X-T, Barrett EFII S32, CAI, MTV-9B
Dues+ Paid 2021,...Thanks DR+
01-15-2022, 11:10 AM
The only time the registration would show Van's as the aircraft manufacturer would be for an RV-12 ELSA kit. Any other RV, including an RV-12 that's built as an amateur-built aircraft, would show the person's name as the "manufacturer" of the aircraft.
So assuming that your aircraft is anything other than an RV-12 ELSA kit, somebody screwed up somewhere along the line. Now is the time to make it right, before the airworthiness inspection comes around.
Cheers!
Joe
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
